older style MP aluminum Hemi head torque #253842
03/14/09 09:32 PM
03/14/09 09:32 PM
closer to Canadian beer!
torkrules Offline OP
I'm neurotic
I'm neurotic
So whats your favorite torque spec for the older style MP aluminum head with ARP studs, ARP special sauce, and cometic gaskets on an iron mega block?
I've heard and read all kinds of theories and specs. Are the inner studs torque to the same value as the deck studs?
Do tell.
Re: older style MP aluminum Hemi head torque [Re: torkrules] #253843
03/15/09 10:44 AM
03/15/09 10:44 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I would be curious to hear other oppinions on this too. I was warned not to torque the valley studs to spec. as it would distort the intake runner and then loose sealing.
This was from a racer with a lot of hemi experience.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: older style MP aluminum Hemi head torque [Re: Hemi Allstate] #253844
03/15/09 11:02 AM
03/15/09 11:02 AM
I'm neurotic
I'm neurotic
Mark
Yup, Ive heard the same thing. I've also heard:
75 on the deck/65 on the valley
65 all around
65 on the deck and 35-40 on the valley
Re: older style MP aluminum Hemi head torque [Re: Hemi Allstate] #253845
03/15/09 11:04 AM
03/15/09 11:04 AM
MIKECS Offline
MIKECS  Offline
Your wright the valley studs are to be torqued to 40lb.
If you listen to the TDG's they will tell you torque them to 75.
DO NOT LISTEN TO THE TDG'S.
40LB THATS IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: older style MP aluminum Hemi head torque [Re: MIKECS] #253846
03/15/09 11:25 AM
03/15/09 11:25 AM
I'm neurotic
I'm neurotic
And to complete the puzzle......the deck studs are torque to......(insert answer here)
Re: older style MP aluminum Hemi head torque [Re: torkrules] #253847
03/15/09 11:35 AM
03/15/09 11:35 AM
Mt. Eden Ky.
Mt. Eden Ky.
I was told to go 70 -75 lbs with moly on the stage v. I can't remember what I used on the MP heads I had.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: older style MP aluminum Hemi head torque [Re: MIKECS] #253848
03/17/09 06:44 PM
03/17/09 06:44 PM
I'm neurotic
I'm neurotic
Not to sound stupid but what is a TDG?
Post deleted by Defbob [Re: MIKECS] #253849
03/17/09 07:33 PM
03/17/09 07:33 PM
Re: older style MP aluminum Hemi head torque [Re: torkrules] #253850
03/17/09 07:45 PM
03/17/09 07:45 PM
New Jersey
Craig Offline
Craig  Offline
New Jersey
I was going (successfully) with the reduced number on the valley studs until a couple years ago when I had just the heads freshened with valves, springs, and a deck cut, and kept getting bad leakdown numbers after a full power run. Deck on block checked out flat. Found gasket embossing rings weren't crushing down at upper part of circle (steel shims, 1970s aluminum heads). Went to same torque on valley studs as head bolts and got good seal. That was after about 4 sets of head gaskets and cleaning, intake and header surface cleaning and sealing, etc, each time with good leakdown readings until after the first full power run.
So I recommend same torque at all points, like the original service manual calls for.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: older style MP aluminum Hemi head torque #253851
03/17/09 07:48 PM
03/17/09 07:48 PM
MIKECS Offline
MIKECS  Offline
I am glad you sleep all night. The valley stud torque has nothing to do with the block. The main issue is the seat in the head the more torque you put on the valley stud the more distortion is on the seat.
TDG = Typical Dode Guy
Re: older style MP aluminum Hemi head torque [Re: Craig] #253852
03/17/09 07:55 PM
03/17/09 07:55 PM
MIKECS Offline
MIKECS  Offline
This is what I mean one tells you one way another tells you something esle.
All the superstock racers and everyone I know does not torque the valley studs to the full torque.
Re: older style MP aluminum Hemi head torque [Re: MIKECS] #253853
03/17/09 09:12 PM
03/17/09 09:12 PM
New Jersey
Craig Offline
Craig  Offline
New Jersey
I heard that for years about the intake seats and it makes sense and I abided by it until I had head sealing issues and it seemed the extra torque was the only fix; the lack of crush on the upper part of the embossing rings on teardown is what convinced me that more torque on the valley studs was needed. If you can seal without it I'm sure that's better but something changed on mine and without a full re-machining of everything the extra torque was the only thing that did the trick.
Re: older style MP aluminum Hemi head torque [Re: MIKECS] #253854
03/17/09 09:31 PM
03/17/09 09:31 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I have heard it affects both the block and head. That's one reason why world has increased the length of the valley boss on their new blocks.
Re: older style MP aluminum Hemi head torque [Re: The Shadow] #253855
03/17/09 10:01 PM
03/17/09 10:01 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
So what is the torque specs on the World block?
Re: older style MP aluminum Hemi head torque [Re: MIKECS] #253856
03/17/09 10:25 PM
03/17/09 10:25 PM
I'm neurotic
I'm neurotic
The block thing can be a factor. I have seen two older original block crack the bosses when they were torqued to factory specs (75 lb.ft on the iron heads). The shop that was doing them reduced the torque on the inner studs to prevent this. This shop was also doing some of the dyno testing for Cummins when they were in Canada. They remember the inner studs being as tight as the deck studs even on the aluminum 528 engines.
Wow, what a can of worms!
Post deleted by Defbob [Re: torkrules] #253857
03/17/09 10:32 PM
03/17/09 10:32 PM
Re: older style MP aluminum Hemi head torque #253858
03/17/09 11:38 PM
03/17/09 11:38 PM
Mt. Eden Ky.
Mt. Eden Ky.
I don't mean to hy jack, and this is the same topic.
What tool are you guys using for the valley stud twelve point nuts? I cannot find a 1/2" twelve point crows foot.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: older style MP aluminum Hemi head torque #253859
03/17/09 11:41 PM
03/17/09 11:41 PM
I'm neurotic
I'm neurotic
So, which one of us is the TDG? Or, are we all TDG's?
I'd be a tPG (plymouth)
Re: older style MP aluminum Hemi head torque [Re: Hemi Allstate] #253860
03/18/09 01:10 AM
03/18/09 01:10 AM
I'm neurotic
I'm neurotic
Mark
Snap-on p/n FRDHI81. I use 9/16" 12 point nuts.
Re: older style MP aluminum Hemi head torque [Re: torkrules] #253861
03/18/09 08:07 AM
03/18/09 08:07 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We always torque OEM style aluminum heads with ARP studs and molylube to 70 lbs ft including the inner stud using the factory sequence.On after market heads(Indy) that use a bolt we do not exceed 40 lbs ft +-.
