Re: older style MP aluminum Hemi head torque
[Re: B G Racing]
#253862
03/18/09 08:35 AM
03/18/09 08:35 AM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
Why torque a oem almn head different than an aftermarket head? Is it because the better deck(thicker) seals w/o as much torque? 40ft/lbs seems light, especally on a race motor? What are you differing on OEM style vs aftermarket?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: kilroy]
#253863
03/18/09 08:50 AM
03/18/09 08:50 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I'am referring to the after market like an Indy head that has a bolt rather than a stud in the lifter valley.A bolt clamps differently than a stud,you are friction loading as well as clamp loading and may pull the threads as well as distort the floor of the intake.There is a redundency as far as friction loading with a stud and the stud thread hole in an OEM style is a through hole whereas the Indy is a blind hole and it's termination is part of the intake floor.
