Transmission removal without a lift #2537748
08/17/18 05:46 PM
08/17/18 05:46 PM
Mequon, WI
gzig5 Offline OP
gzig5  Offline OP
Mequon, WI
How high am I going to need to block up my 73 Cuda to remove the 727 Torqueflight for a rebuild? No lift available. I have a good floor jack and would probably make an adapter plate to strap the trans to the lift for bringing it down. The shops I've been talking to want an extra $400+ for them to do the in/out. Seems like I'd need to get it higher than it is currently on stands that are fully extended.
Re: Transmission removal without a lift [Re: gzig5] #2537755
08/17/18 05:59 PM
08/17/18 05:59 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the problem you will find is when the car is high enough to drop the tranny out your floor jack cant jack high enough to put the tranny back in----get out your tape measure-----you need 17 inches clearance to pull the tranny on the floor under the floorboards----it cant even be on the jack at that point----putting it back in---slide it on the floor----get under the car with the jack----lift up the tranny and put it up on the jack----jack up the jack and wish that the jack could go higher.....
Re: Transmission removal without a lift [Re: savoy64] #2537783
08/17/18 06:42 PM
08/17/18 06:42 PM
Conway, SC
T2R9 Online confused
T2R9  Online Confused
Conway, SC
That's how I have always done it. Get it down, slide it off the jack and drag it out on the floor. In in the reverse order. My new shop is getting a lift cause I am getting too old for that!
Re: Transmission removal without a lift [Re: gzig5] #2537790
08/17/18 06:49 PM
08/17/18 06:49 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Get a low profile transmission jack and it isn't too bad to change one on jack stands.
Re: Transmission removal without a lift [Re: gzig5] #2537831
08/17/18 08:19 PM
08/17/18 08:19 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The problem I had with my first trans jack was to get the car high enough to get the jack and trans out from under the car then there wasn't enough lift to get the trans up high enough to bolt back up. The one I have now will lift 30 inches from floor to bottom of pan. I made 14" high boxes that the tires set on, no jack stands. Strips front and back to keep from rolling off.
Still a pain at 69.
Lifts a Black Hawk big truck type.
Re: Transmission removal without a lift [Re: gzig5] #2537835
08/17/18 08:26 PM
08/17/18 08:26 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I use a motorcycle jack to RR trans with car on jackstands.....Sometimes need to lift car a little higher to get trans in and out on jack. No biggie.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Transmission removal without a lift [Re: gzig5] #2537850
08/17/18 08:59 PM
08/17/18 08:59 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
https://www.harborfreight.com/450-lbs-low-lift-transmission-jack-61232.html
these things work great...and get a 20% of coupon...
Tony
70 AARCuda Vitamin C
Re: Transmission removal without a lift [Re: gzig5] #2537862
08/17/18 09:20 PM
08/17/18 09:20 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
suggestion- make sure to get the upper bellhousing bolts out from the top before putting the car on jackstands
Re: Transmission removal without a lift [Re: gzig5] #2537887
08/17/18 09:52 PM
08/17/18 09:52 PM
cbusters Offline
cbusters  Offline
$200 each way. No fluid to clean up, no cuts, no bruises, no mistakes and no oh shits. Drive in, drive out. Why would you want to do it yourself?
Re: Transmission removal without a lift [Re: 70AARcuda] #2537908
08/17/18 10:23 PM
08/17/18 10:23 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
This +6ton jack stands, no problem.
I have a pair of 12tons that get things a little higher, but 6tons will do.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Transmission removal without a lift [Re: 70AARcuda] #2537917
08/17/18 10:42 PM
08/17/18 10:42 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I agree,I've used one with jack stands no problem.
Re: Transmission removal without a lift [Re: 70AARcuda] #2538019
08/18/18 08:42 AM
08/18/18 08:42 AM
BDW Online content
BDW  Online Content
This and a used Kwik Lift made my 518 swap easy
Re: Transmission removal without a lift [Re: mgoblue9798] #2538033
08/18/18 09:50 AM
08/18/18 09:50 AM
KY
65pacecar Offline
65pacecar  Offline
KY
Definitely, makes the job much easier.
Re: Transmission removal without a lift [Re: gzig5] #2538036
08/18/18 10:00 AM
08/18/18 10:00 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
I did quite a few on the ground.Even before I had a good floor jack.Just get it high enough.I pulled the dip stick tube first after draining fluid.Ive done my 4 speed on the ground also.Used to set it on my chest and heft it into place.last time I didthe 4 speed had my sons stab it in.LOL One advantage to having grown sons whe you get old.Rocky
Chrysler Firepower
Re: Transmission removal without a lift [Re: gzig5] #2538086
08/18/18 12:36 PM
08/18/18 12:36 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
18 inches should do it with just a couple inches to spare. EDIT 18 inches PLUS the height of your jack, cradle, etc (unless you can slide the jack apparatus out from under the transmission once lowered)...
Re: Transmission removal without a lift [Re: savoy64] #2538093
08/18/18 12:46 PM
08/18/18 12:46 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've changed a bunch this way, before I had a floor jack I'd drag them up on my abdomen and lift them up in place. Too old for that now, have a lift and high lift transmission jack, much easier now. lol
Re: Transmission removal without a lift [Re: gzig5] #2538096
08/18/18 12:58 PM
08/18/18 12:58 PM
5thAve Offline
5thAve  Offline
Skip the transmission jack, it makes it too high and awkward to get out when you're doing it on the floor. A normal floor jack is all you need. Like others said if the car is too low to get it out slide it off the jack, I usually put cardboard down to make it easier to slide around. The last one I pulled took less then an hour.
Re: Transmission removal without a lift [Re: gzig5] #2538098
08/18/18 01:04 PM
08/18/18 01:04 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I like using the Harbor Freight 12 ton jackstands for the front and the regular 6 ton stands for the rear axle. 1 set of 4 of each of those jackstands and a Costco $90 3-ton floor jack have served me well for decades.
I use the regular floor jack to slide it in and out with no issues, but it has slipped off once or twice. Hands to self when that happens. I can still lift them up and put it in by hand, but only because I work out at the gym. If I don't go regularly, that ability goes away and chance of injury in general goes up.
I've been R&R'ing the trans for 40 years by myself that way. A lift would require a dedicated, tall transmission jack for lifts, and then the lift is in the way in a small shop.
Lifting the car up onto the highest setting of the 12 tone jackstands makes it nice for polishing the sides and lowers too.
Re: Transmission removal without a lift [Re: gzig5] #2538117
08/18/18 01:26 PM
08/18/18 01:26 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Done it many times with other cars too..I used the jack with a piece of wood, dropped it down and dragged it out on the floor with cardboard.
Re: Transmission removal without a lift [Re: AARCONV] #2538147
08/18/18 02:48 PM
08/18/18 02:48 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Ever try and do one without anything but your body ? I did years ago,in and out but I was young and dumb then,now just dumb !! realcrazy
