Portable air compressor reccomendation #2537921
08/17/18 11:00 PM
08/17/18 11:00 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Looking for something reliable and affordable for use while at the track to fill tires. What are you guys using?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Portable air compressor reccomendation [Re: BloFish] #2537925
08/17/18 11:14 PM
08/17/18 11:14 PM
southeast ky
mills.mopar Offline
mills.mopar  Offline
southeast ky
I carry a tank of nitrogen. I keep it for track only use. Lasts me a long time. Like half season. Tank is a small one too.
Jeff.
If you love it lube it
68 dart
37 dodge coupe
71 challenger
Re: Portable air compressor reccomendation [Re: BloFish] #2537933
08/17/18 11:34 PM
08/17/18 11:34 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Hands down, California Air Tools.
Re: Portable air compressor reccomendation [Re: BloFish] #2537973
08/18/18 01:30 AM
08/18/18 01:30 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I use a CO2 tank...Its about 8" in diameter and produces much better pressure than a small compressor.
Re: Portable air compressor reccomendation [Re: BloFish] #2537982
08/18/18 01:55 AM
08/18/18 01:55 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
I just got a cheep pancake one from HF
Re: Portable air compressor reccomendation [Re: BloFish] #2538012
08/18/18 07:18 AM
08/18/18 07:18 AM
Washington
skrews Offline
skrews  Offline
Washington
^ this
Re: Portable air compressor reccomendation [Re: skrews] #2538045
08/18/18 10:47 AM
08/18/18 10:47 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
HF it holds 100lbs of press. and was only 54.00
Re: Portable air compressor reccomendation [Re: BloFish] #2538048
08/18/18 11:15 AM
08/18/18 11:15 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
For just adjusting tire pressures these are hard to beat.
If you have other Ryobi tools you can get one without a battery or charger.
https://www.homedepot.com/p/Ryobi-18-Volt-ONE-Lithium-Ion-Cordless-Power-Inflator-Kit-with-1-3-Ah-Battery-and-18-Volt-Charger-P737KN/302634287?cm_mmc=Shopping%7CG%7CBase%7CAll-Products%7CAll%7CAll%7CPLA%7c71700000014585962%7c58700001236285396%7c92700010802552382&gclid=EAIaIQobChMIr-XYkdf23AIVB1p-Ch1bewVpEAQYASABEgI6gPD_BwE&gclsrc=aw.ds&dclid=CPPO9ZbX9twCFQLPZAod2FcMGA
Re: Portable air compressor reccomendation [Re: BloFish] #2538463
08/19/18 10:08 AM
08/19/18 10:08 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I'll second the Ryobi inflator. It's not a quick way to fill a flat tire but for making pressure adjustments it works great.
68 Barracuda Formula S 340
Re: Portable air compressor reccomendation [Re: BloFish] #2538682
08/19/18 09:04 PM
08/19/18 09:04 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Here's the Ryobi link......
Re: Portable air compressor reccomendation [Re: BloFish] #2539418
08/21/18 03:30 AM
08/21/18 03:30 AM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
I wish Dewalt had a similar product, as I gave away all,of my Ryobi tools.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Portable air compressor reccomendation [Re: BloFish] #2539468
08/21/18 10:30 AM
08/21/18 10:30 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I have this one and so far it's been great.
https://www.lowes.com/pd/Hitachi-4-Gallo...ssor/1000044881
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Portable air compressor reccomendation [Re: Dragula] #2539484
08/21/18 11:07 AM
08/21/18 11:07 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have been using portable tanks like this one since the eighties when we were dirt bike riding. I have used both nitrogen and CO2 to air tires. Back in the early days I used a portable tank because we did not have a genset or an electric compressor.
Then when we had a big genst and electric compressor we still used a portable tank to take to the lanes to do tires with.
This one has a preset regulator set at 140 PSI meaning I can use it to air the 115PSI tires on my RV which my electric compressor would struggle to get done.
This is reliable and pretty cheap. IMO it is more reliable than a HF cheapo compressor. In the evening you can hook it up to your quarter barrel of draft beer too! up I either carry a mother tank to refill it or spare 5# tank.
When I carry them in my trailers, I use aluminum tanks.
Re: Portable air compressor reccomendation [Re: BloFish] #2539497
08/21/18 11:33 AM
08/21/18 11:33 AM
Norfolk, NE
Racer33 Offline
Racer33  Offline
Norfolk, NE
Go to the Dewalt website and take a look. They have a 20V corded/cordless compressor. I haven't tried it yet but it is on my list of things before next years race season.
Re: Portable air compressor reccomendation [Re: BloFish] #2539528
08/21/18 12:25 PM
08/21/18 12:25 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I have two of these also...super handy in the lanes at the track.
https://www.homedepot.com/p/Ryobi-18-Volt-ONE-Cordless-Power-Inflator-Tool-Only-P737/206159256
