Page 2 of 3 1 2 3
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2535740
08/13/18 05:31 PM
08/13/18 05:31 PM
GA
roadrunninMark Offline
GA
I have a pic of them side by side...
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2536126
08/14/18 12:58 PM
08/14/18 12:58 PM
IL
furious70 Offline OP
IL
Is that from the interwebs or do you have all 3 and can take more photos? If so I'd really appreciate it!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2536188
08/14/18 02:51 PM
08/14/18 02:51 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Wow, the NAG looks like it’ll fit without to much tunnel surgery. If someone would do a kit for these transmissions for retrofits I think they’d sell
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2536221
08/14/18 03:38 PM
08/14/18 03:38 PM
IL
IL
Darius had to raise his tunnel in a B body per his build thread, didn't look terrible. I'd like to see more photos and measurements to gauge the fit.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2536525
08/15/18 12:16 AM
08/15/18 12:16 AM
GA
GA
I had someone send me the pic. I've had it a long time. I've talked to a person who put the NAG1 in an ebody, he said all he had to do was do some bending of the dipstick tube to get it to fit.
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2537266
08/16/18 04:37 PM
08/16/18 04:37 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
A buddy built a 71 Challenger Convertible with a 392 and a NAG1 trans.
Here's a link to his website with pics on the build. http://www.lotsapins.com/Hemiswap/pics.htm
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2537285
08/16/18 05:27 PM
08/16/18 05:27 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The crossmember is further back on an e-body vs b-body... that makes a world of difference in a 518 swap also. I imagine it's the same deal for these transmissions.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2537466
08/17/18 01:09 AM
08/17/18 01:09 AM
IL
IL
going back through cbodydrydock.com threads I found this pic showing tunnel mods when running the 545RFE. Now I want the dimensions of the 545RFE as well to compare :P
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2537801
08/17/18 07:11 PM
08/17/18 07:11 PM
IL
IL
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2538965
08/20/18 12:18 PM
08/20/18 12:18 PM
IL
IL
I was changing the oil in my 2012 charger this weekend with the 3.6 and TF8. I couldn't get any good measurements of the TF8 in the car but it's near 30" bellhousing to mount and at the mount still seemed to be 9" tall (9" diameter). It's a big dude. The tunnel in the car looks huge from the underside.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2542449
08/28/18 01:00 PM
08/28/18 01:00 PM
GA
GA
Good find on the pics! Yes, the 8 speed is huge. There is a guy on Facebook putting one in a car...let me see if I can find the info for you.
Joel Applegate is his name. He frequents the page G3 Hemi Swap. Here is a picture of his swap, but doesnt show you much. There are two sizes of the 8 speed, the "90" and the "70". The "70" is smaller but doesn't handle as much hp.
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: roadrunninMark] #2542541
08/28/18 03:17 PM
08/28/18 03:17 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Where on Facebook is this swap and what is he using for a controller?
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2542572
08/28/18 04:05 PM
08/28/18 04:05 PM
GA
GA
The page is called G3 Hemi Swap. I don't know the details on a controller or if he is using all the factory stuff. I know people are working on it to try and crack the code.
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2543890
08/31/18 03:36 PM
08/31/18 03:36 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Just a thought, I was under my 93 Mersedes 300 SD and noticed that trans looks just like the Nag One. Bell bolts on just like the Nag plus this trans has a shifter and is modulated by vacuum. This is a 4 speed but the gas engines are 5 speed. No computers, no electronics.
If they s would work, what an option.
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2543932
08/31/18 05:57 PM
08/31/18 05:57 PM
IL
IL
hmmm, I know they made them for a long time, but is there actually a hydro/vac controlled 5spd version that handles any real torque? That would be really intriguing if you can bolt on a hemi bell...
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2543979
08/31/18 08:08 PM
08/31/18 08:08 PM
IL
IL
wikipedia only says this
722.5 — 5-speed (hydraulically controlled 4-speed with additional electrically controlled 5th overdrive gear)
no actual page for it, but a page for the 4spd before and the 722.6, of course :P
google isn't being my friend, can't find much about the trans, it's construction, or torque rating
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2543981
08/31/18 08:15 PM
08/31/18 08:15 PM
IL
IL
this one does not have a bolt on bell and is much skinnier than a .6
https://www.ebay.com/itm/94-97-Mercedes-R129-SL320-Automatic-Transmission-Assembly-722-507-76k/113145830970?hash=item1a58045e3a:g:VAYAAOSw4v1bRvto
this might be worth $10 tho lol
https://www.ebay.com/itm/ATSG-Mercedes-722-5-manual/273422192424?hash=item3fa93b8f28:g:QRwAAOSwQ19arXdx
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2544054
09/01/18 12:01 AM
09/01/18 12:01 AM
IL
IL
I asked Russell Drake about them and he said the 722.5 is weak, only went behind v6.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2544088
09/01/18 01:11 AM
09/01/18 01:11 AM
fredericksburg,va
fredericksburg,va
The S class cars will have the better one. Mines a turbo 6 and the gas is a straight 6 and V8.
The lowly PG wasn't much before the aftermarket got there hands on it either.
Re: Any1 use the NAG1 or torqueflite 8 in an old mopar? [Re: furious70] #2544254
09/01/18 01:40 PM
09/01/18 01:40 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
so what do you do with that clunky mercedes shifter? looks like it would be hard to cut down to fit into a stock console.....i am leaning toward a 46HD where you can use the stock shifter and console-----with this much power i cant see the need for a 6 or 8 speed unless its is just to brag about all the gears and how cool it is.........
Page 2 of 3 1 2 3
