1969 Bahama Yellow #2537739
08/17/18 05:34 PM
08/17/18 05:34 PM
SE Michigan
U
ubercuda Offline OP
ubercuda  Offline OP
U
SE Michigan
Anybody think any of these yellows are close...if yes which one? http://www.tcpglobal.com/Restoration-Shop/
Re: 1969 Bahama Yellow [Re: ubercuda] #2537757
08/17/18 06:04 PM
08/17/18 06:04 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I picked 3 that are "close", but keep in mind, that shade value/primer base can alter a color slightly, buy the minimum you can and do a spray out to see if it's what you want... I'm leaning towards Boss Yellow with a dark primer/shade value 4-5
Mike
Re: 1969 Bahama Yellow [Re: ubercuda] #2537760
08/17/18 06:08 PM
08/17/18 06:08 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Is there a reason you are forced to use only this supplier?
I absolutely love Bahama Yellow and would hate to see it not as intended.
Re: 1969 Bahama Yellow [Re: AAR#2] #2537764
08/17/18 06:16 PM
08/17/18 06:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'm sure he'd be your bestest friend if you bought him all the "correct" Bahama Yellow paint and supplies you feel he needs for HIS "intended" paint project... smile
Re: 1969 Bahama Yellow [Re: AAR#2] #2537937
08/17/18 11:46 PM
08/17/18 11:46 PM
SE Michigan
U
ubercuda Offline OP
ubercuda  Offline OP
U
SE Michigan
Just being frugal. I may go with the correct color...I was just seeing what others thought. Thanks Dayclona for your choices.
Re: 1969 Bahama Yellow [Re: DAYCLONA] #2537992
08/18/18 02:39 AM
08/18/18 02:39 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
No problem Dayclona, last I checked we were posting on the “Restoration” site, where correct should be considered. But you’re correct, it is HIS project and hes welcome to paint it with anything he likes
Re: 1969 Bahama Yellow [Re: ubercuda] #2538059
08/18/18 11:44 AM
08/18/18 11:44 AM
SE PA
cudaize Offline
cudaize  Offline
SE PA
If you are looking for the proper mix economically I would investigate the PPG low end single stage, I believe called shop line. As of about 4-5 years ago they could mix EL5 in this but for some reason did not have the code for the high end single stage.
Re: 1969 Bahama Yellow [Re: ubercuda] #2538078
08/18/18 12:28 PM
08/18/18 12:28 PM
MO
cdp Offline
cdp  Offline
MO
How close is GM's 1971 Ochre color? Its kind of Bahama Yellow-ish... puke
Re: 1969 Bahama Yellow [Re: ubercuda] #2544973
09/03/18 10:57 AM
09/03/18 10:57 AM
Port Saint Lucie, FL
ChallengerGary Offline
I have sprayed Nason Single Stage Urethane Bahama Yellow a couple of times. Price should be right in line with the TCP Global stuff and you will get the actual color you want. Absolutely no need for base clear if you are looking to save money. If you want a little added depth of shine/gloss, you can use some integrated clear in the final coat but bear in mind, it will not look correct then as it will be a little too glossy versus the factory paint
Re: 1969 Bahama Yellow [Re: ChallengerGary] #2546072
09/05/18 11:23 AM
09/05/18 11:23 AM
SE Michigan
U
ubercuda Offline OP
ubercuda  Offline OP
U
SE Michigan
Thanks for the tip....I will look into using the Nason. Still a week or two away from having it ready for color.
