New motor's killin me... #2537493
08/17/18 04:10 AM
08/17/18 04:10 AM
Dearborn Hts, MI
Sledge_57 Offline OP
Dearborn Hts, MI
Had a new motor built, 500" 400 block, 10.8 compression, .629 lift, 263@.050, my Bulldog heads from old motor, MP M1 single plane, Holley HP 950, MSD Pro billet Dist and 6al and TTI step headers 2" - 2 1/8".
It runs but not well. We're pretty sure it's a vacuum leak at the intake. First we found one of the extra four carb mounting holes for AVS style carbs (I guess) was drilled all the through to the plenum. We fixed that but still seem to have a sizable vacuum leak.
We suspect the intake's not sealing to the heads well, looking at the gasket after pulling intake could see indents along top of gasket where manifold was sealed but nothing along the bottom. Used intake of course but it looked as if it was never on a motor before. Cylinders on even side seem to have the issue based on temps at header tubes. Odd side was showing ~200* (didn't run it long) even side (#2 specifically) ~85* We checked and we know we're getting spark btw...
Tried thicker gaskets and used a little sealer, better but still not right.
Looking for a way to track it down, other than spraying carb cleaner trick, we tried that and found nothing.
Might put old Performer RPM on tomorrow I think to see if it makes a difference but would like to try to get the M1 to work
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: New motor's killin me... [Re: Sledge_57] #2537528
08/17/18 08:55 AM
08/17/18 08:55 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Were the chambers vacuum checked after the heads were assembled? I've had 2 sets of Bulldog heads where the seats were cracked or crumbling away. Always had a chamber or three that would not vac check.
Re: New motor's killin me... [Re: Sledge_57] #2537529
08/17/18 08:56 AM
08/17/18 08:56 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I cheated and brought home the smoke machine from work for checking evap leaks. Showed me a lot of my issues from start up. You can put the intake on without the gaskets to check mating surfaces and angles. I think that .003" gap would be max before clean milling the intake to match the heads.
[image][/image]
Re: New motor's killin me... [Re: Sledge_57] #2537537
08/17/18 10:06 AM
08/17/18 10:06 AM
South Lyon, Michigan
6bblRoadrunner Offline
I ran into the same issue with my factory 6bbl intake. Block and heads cut and had vacuum leak as you described. I ended up finding this write-up on Hughes site. I did as described and it worked out well for me.
http://www.hughesengines.com/Upload/TechArticles/INTAKE_MANIFOLD_SEALINGJULY2015.pdf
Re: New motor's killin me... [Re: 6bblRoadrunner] #2537601
08/17/18 01:04 PM
08/17/18 01:04 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Good article: Thanks for sharing
Re: New motor's killin me... [Re: Sledge_57] #2537614
08/17/18 01:28 PM
08/17/18 01:28 PM
I have sat the intake on the heads, make sure all the flat surfaces are clean and ding free, to check the alignment and then used a feeler gauge to measure all four corners with a feeler gauge at the top and bottom of the intake to head mating surfaces. don't be surprise to see some at zero and some as bad as .015+ scope wrench
Write the clearances down for each corner and then take that manifold to a good machine shop and have them surface it to cure the machining differences, if the bolt holes in the manifold are above the ones in the heads you may need to have additional material removed to get the port alignment better, if below then add gaskets (stack them if needed up) to raise the intake up to align the manifold scope
Re: New motor's killin me... [Re: Sledge_57] #2537631
08/17/18 01:53 PM
08/17/18 01:53 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Here's a little idea that we tried on my friends motor. With the intake off, stuff some rags down each intake runner on the heads. Run double sided tape across the intake face of each head. If your tape is not wide enough, make sure it just butts edge to edge and no overlap. Then stick some strips of sand paper on the tape, grit side up. Start with course grit and work to finer. Place the intake on this and slowly slide it back and forth to match the surfaces. Depending on how far out the intake faces are, this should not take very long. Once done, you should have perfectly matched faces of intake to heads. Caution, do not go overboard on this as to cause misalignment with the ports.
Re: New motor's killin me... [Re: Sledge_57] #2538001
08/18/18 03:38 AM
08/18/18 03:38 AM
Dearborn Hts, MI
Dearborn Hts, MI
Thanks for the replies and suggestions.
We tried my Performer RPM intake that had been used with these heads before and had the same issue, also tried another carb I used on my old 470. Still the same.
After all was said and done we discovered it wasn't a vacuum leak at all.
It was the power valves. My HP 950 came jetted square with 79 mains and 6.5 PV's. We knew 6.5 wouldn't work, we dropped them to 3.5 and that's what was in when we thought it was a vac leak.
Finally realized 3.5 wasn't low enough and installed PV block off plugs.
Ran perfect, idling right at 1000 rpm.
Now, how much to increase jetting without PV's?
Doug
Re: New motor's killin me... [Re: Sledge_57] #2538011
08/18/18 07:15 AM
08/18/18 07:15 AM
Washington
skrews Offline
skrews  Offline
Washington
8-10 to sizes.
Re: New motor's killin me... [Re: skrews] #2538022
08/18/18 08:56 AM
08/18/18 08:56 AM
sgcuda Offline
sgcuda  Offline
Originally Posted By skrews
8-10 to sizes.
iagree
Re: New motor's killin me... [Re: Sledge_57] #2538042
08/18/18 10:28 AM
08/18/18 10:28 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
This looks like a street motor to me. As long as the power valve isn't ruptured it will have no effect at idle. If the carb is lean at WOT the power valve channel restrictions can be opened to richen WOT. This will allow a leaner mixture for cruise on the street. No way the power valve needs to be blocked for street use. This will just cause cruise to be dead rich.
Doug
Re: New motor's killin me... [Re: dvw] #2538052
08/18/18 11:31 AM
08/18/18 11:31 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
iagree
Master, again and still
Re: New motor's killin me... [Re: Sledge_57] #2538053
08/18/18 11:31 AM
08/18/18 11:31 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Sledge!!! Now bring that pedal car to Mopars at Milan next month.
Re: New motor's killin me... [Re: Sledge_57] #2538060
08/18/18 11:44 AM
08/18/18 11:44 AM
Dearborn Hts, MI
Dearborn Hts, MI
OK one more thing I remembered from last night and I think this may have been the culprit.
When I pulled the secondary PV it had 2 gaskets, can this cause it to dump fuel?
Seriously the car wouldn't even run until we blocked the PV's. I'm going to check vacuum today to see where it is and try PV's again.
It was impossible to check it before had to keep it over 1500 to stay lit and was missing badly.
Kathy, I'm hoping to...
Doug
Re: New motor's killin me... [Re: Sledge_57] #2538069
08/18/18 12:13 PM
08/18/18 12:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The jet spread depends on the size of the pvcr's but a 2.5 or 3.5 rarely belongs in ANYTHING so you need to clean up the idle/transition circuits first then start tuning again. Cruise is where/why the p/v's work or not NOT idle and my Dart has 5 in. of vacuum at idle and I run a 6.5 but cruise at 12 in so when I crowd the throttle under load, it opens up giving me the enrichment I need accordingly..........That carb needs work and not just jetting but a complete make over and if u call me I can help ya out if u'd like.........
Re: New motor's killin me... [Re: Thumperdart] #2538280
08/18/18 10:50 PM
08/18/18 10:50 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
make the call,,,,you will be glad you did. up
Re: New motor's killin me... [Re: Sledge_57] #2538359
08/19/18 12:51 AM
08/19/18 12:51 AM
Dearborn Hts, MI
Dearborn Hts, MI
Put a vacuum gage on it today and has a steady 9in at idle with PV's blocked so at least I have a starting point. I have to assume that second gasket on the PV that we didn't know was there was the original problem
Doug
Re: New motor's killin me... [Re: Sledge_57] #2538551
08/19/18 02:18 PM
08/19/18 02:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If you run a plugged p/v on the street you are doing nothing towards fixing the issues and creating more nasty oil fouling richness......... beer
Re: New motor's killin me... [Re: Thumperdart] #2538825
08/20/18 02:19 AM
08/20/18 02:19 AM
Dearborn Hts, MI
Dearborn Hts, MI
I have no intention of leaving this way Dom, but it was the only way it'd run. Like I said, based on the amount of vacuum I have it must have been the extra gasket I accidentally put under the PV, other than changing the PV's this carb is just as it came from Holley.
Nothing else makes sense to me, unfortunately working out of town next week so it'll have to wait till next weekend, gonna start with a 4.5 PV in the primary and go from there.
Here's a small vid
https://youtu.be/qkr0uWS2gcE
Doug
Re: New motor's killin me... [Re: Sledge_57] #2538873
08/20/18 08:39 AM
08/20/18 08:39 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The car sure looks great, Doug. I'm sure you'll figure it out soon.
These kind of issues are part of what led me down the path to air/fuel ratio gauges. I bet if you could grab one it'd give helpful directional info. Just a thought. Good luck.
Rich H.
Esse Quam Videri
