Hellcat conversion > auto transmission #2537037
08/16/18 07:44 AM
08/16/18 07:44 AM
N of Detroit
DaveDudek Offline OP
N of Detroit
Hello, looking to swap a Hellcat crate engine into a 69 B-body.. What are my options if we want to use an automatic transmission? Does someone sell a kit?
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: Hellcat conversion > auto transmission [Re: DaveDudek] #2537138
08/16/18 01:10 PM
08/16/18 01:10 PM
USA
hudsonhornet7x Online content
hudsonhornet7x  Online Content
USA
Dave,
The 727 is the easiest, if you want overdrive without worry of blowing the thing up I would say 4l80E.
As far as the Mopar Nag-1 and 8 speed transmissions, They are much more work.
I believe hotwire sells a Nag controller but you still have to put sensors, tone rings, etc on the driveline. Way to much hassle in my opinion.
The Hellcat plug and play kit is for the engine only, it will not control a transmission.
Hope this helps
Re: Hellcat conversion > auto transmission [Re: hudsonhornet7x] #2537173
08/16/18 02:11 PM
08/16/18 02:11 PM
N of Detroit
N of Detroit
Thank you.. A 727 will bolt right up? Converter/flexplate?
Dave Dudek
Re: Hellcat conversion > auto transmission [Re: DaveDudek] #2537186
08/16/18 02:32 PM
08/16/18 02:32 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Small block 727 will and you need a conversion flexplate or you can have the converter modified. If your not against cutting some, you can go with a 518 with od... but needs the t-bar crossmember modified and a little tunnel work.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Hellcat conversion > auto transmission [Re: DaveDudek] #2537187
08/16/18 02:32 PM
08/16/18 02:32 PM
USA
USA
Dave,
A small block 727 will bolt right up but you do need a special flexplate that Mopar performance sells. I believe there are other aftermarket choices as well.
Also, you have a pm on another matter. Thanks!
Re: Hellcat conversion > auto transmission [Re: DaveDudek] #2540337
08/23/18 10:35 AM
08/23/18 10:35 AM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I used a 4L80 with a Holley EFI
