Re: calculating peak rpm hp [Re: Cab_Burge] #2536863
08/15/18 07:27 PM
08/15/18 07:27 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I agree cab and if i would have never asked any of my silly questions i wouldnt have learned much. Been learning good stuff off this site for a long time now.
Re: calculating peak rpm hp [Re: B3422W5] #2536864
08/15/18 07:31 PM
08/15/18 07:31 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Originally Posted By B3422W5
Originally Posted By mopar dave
For sure, but thought i might try short shifting at 6000 to start. Then 6500 and go from there.
Any such way like that will ultimately find out what i likes best.
Love ya man, but frankly you make things more involved and harder than anybody that has ever posted on here... lol
WOW 😮. That wasn’t a very cool thing to post. LOL.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: calculating peak rpm hp [Re: mopar dave] #2536868
08/15/18 07:36 PM
08/15/18 07:36 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
nothing wrong with checking others opinion/experience , if only to confirm you are heading in the right direction .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: calculating peak rpm hp [Re: B3422W5] #2536961
08/15/18 11:55 PM
08/15/18 11:55 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... frankly you make things more involved and harder than anybody that has ever posted on here... lol
I thought that was MY claim to fame? whistling
Re: calculating peak rpm hp [Re: BradH] #2536982
08/16/18 12:44 AM
08/16/18 12:44 AM
Mt Morris Michigan
Mt Morris Michigan
Could be, seems you two only answer my threads when you have something non contributing to say. Its real easy, you dont like my questions, then dont answer them. Plain and simple. Plenty of other guys here very helpful. I have have learned plenty from the others on here.
Re: calculating peak rpm hp [Re: BradH] #2536983
08/16/18 12:44 AM
08/16/18 12:44 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I will second that. work up
Re: calculating peak rpm hp [Re: mopar dave] #2537050
08/16/18 08:55 AM
08/16/18 08:55 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Ask any questions you like. That's how we all learn. There are never stupid questions, only stupid people. Lol! Some people on here make comments about the repetition of questions. Sometimes we forget that people come and go off of this site all of the time. What people need answers to aren't in the first couple of pages listed and we all know too well how wonderful the SEARCH function works on here.
My old combo with a 262/266 lift on my 440 liked a 6,800 rpm shift point. Car would slow down with a 6,500 or 7,000 shift. You'll find the sweet spot real quick.
Re: calculating peak rpm hp [Re: mopar dave] #2537060
08/16/18 09:57 AM
08/16/18 09:57 AM
Washington
madscientist Offline
Washington
FWIW once you establish your shift speed, you may want to try changing RPM for just one gear. For example, you may be able to run the 2-3 shift out a bit more than the 1-2 shift. Or it could be the opposite. It's not always that the engine wants to be shifted at the same RPM at every shift change.
Re: calculating peak rpm hp [Re: sgcuda] #2537066
08/16/18 10:14 AM
08/16/18 10:14 AM
Mt Morris Michigan
Mt Morris Michigan
Well i could have just asked who on here has a engine combo simmular to mine that knows their max hp rpm, but i thought maybe their might be a calculator for this i didnt know about. I know the track will tell exactly what its gonna want, but just driving it sounds and feels like its about the 6600-6800 area. Will see. Thanks
Re: calculating peak rpm hp [Re: madscientist] #2537069
08/16/18 10:20 AM
08/16/18 10:20 AM
Mt Morris Michigan
Mt Morris Michigan
I may just give that a try. Watching the vid the tach is not moving much on the 1 2 shift, but the tires were spinning pretty good and spin even more now that i have the fuel mix better sorted out. Looks like 600rpm drop on the 2 3 shift which is same character of the vert when it was behind my 408sb.
Re: calculating peak rpm hp [Re: tex013] #2537093
08/16/18 11:36 AM
08/16/18 11:36 AM
moparx Offline
moparx  Offline
Tex
i do this often to be sure my old mind hasn't forgotten what i used to know. biggrin what's this thread about ?
beer
Re: calculating peak rpm hp [Re: mopar dave] #2537104
08/16/18 12:02 PM
08/16/18 12:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
This^^^
All modern transmission have "ratio progression" in which the RPM % drop on shift is widest on the 1-2, and closes up as you reach final drive.
Boffin Emeritus
Re: calculating peak rpm hp [Re: madscientist] #2537220
08/16/18 03:36 PM
08/16/18 03:36 PM
BradH Offline
BradH  Offline
A couple of Stock Eliminator people I know shift their 1-2 200-300 RPM lower than their 2-3. Never tried it on my junk, simply cuz I position the tach "straight up" at the RPM where I shift for easy reference.
Also, I don't use a shift light any more; I was always late on the shift when waiting for the light at the specified RPM. I'm more consistent w/ the approach above.
Regardless, I was never aware of any major shift lag time that caused my actual shifts' RPMs to be so much higher like some of you said. I'd like some type of data logger or playback tach to see what's happening across the whole pass, though.
Re: calculating peak rpm hp [Re: BradH] #2537228
08/16/18 03:41 PM
08/16/18 03:41 PM
PA.
"Little"John
"Little"John
PA.
A powerglide kinda simplifies this option
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: calculating peak rpm hp [Re: BradH] #2537231
08/16/18 03:45 PM
08/16/18 03:45 PM
Mt Morris Michigan
Mt Morris Michigan
Yeah i agree. Ill have to get back in the habit of watching the tach. The shift light gave me the opportunity to watch another gauge or two(oil and fuel pressure) going down the track. I barely remember, but it seems like i tried this way back with my small block not seeing much if any difference.
Re: calculating peak rpm hp [Re: pittsburghracer] #2537234
08/16/18 03:48 PM
08/16/18 03:48 PM
Mt Morris Michigan
Mt Morris Michigan
Guess i could launch in 2nd gear.
Re: calculating peak rpm hp [Re: mopar dave] #2537290
08/16/18 05:43 PM
08/16/18 05:43 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You may also see different converter slippage on different shifts: the 1-2 has more torque, but the 3-4 is against higher load.
Once you find what works for you, the reason sort of matters less...
Boffin Emeritus
Re: calculating peak rpm hp [Re: polyspheric] #2537294
08/16/18 05:58 PM
08/16/18 05:58 PM
Mt Morris Michigan
Mt Morris Michigan
Ok thanks. Didnt know that. Looking at the vid again on the big screen i see the 2 3 shift rpm drops 400rpm. Looks like it stays right in the power band all the way thru. I guess this would be a good thing?
Re: calculating peak rpm hp [Re: mopar dave] #2537334
08/16/18 07:17 PM
08/16/18 07:17 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
At the pure stock drags, where you weren't allowd to add a tach, they use to say "when the fender starts to lay down, SHIFT"
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: calculating peak rpm hp [Re: Hemi_Joel] #2537339
08/16/18 07:26 PM
08/16/18 07:26 PM
Mt Morris Michigan
Mt Morris Michigan
There is a feel to it for sure. I grew up with 4 speed cars. I have a good feel when to shift. Nosing over might be a bit to late, but im definitely no professional .
