Hellcat conversion > auto transmission
#2537037
08/16/18 07:44 AM
08/16/18 07:44 AM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Hello, looking to swap a Hellcat crate engine into a 69 B-body.. What are my options if we want to use an automatic transmission? Does someone sell a kit?
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
Re: Hellcat conversion > auto transmission
[Re: hudsonhornet7x]
#2537173
08/16/18 02:11 PM
08/16/18 02:11 PM
DaveDudek
N of Detroit
Thank you.. A 727 will bolt right up? Converter/flexplate?
[Re: DaveDudek]
#2537186
08/16/18 02:32 PM
08/16/18 02:32 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Small block 727 will and you need a conversion flexplate or you can have the converter modified. If your not against cutting some, you can go with a 518 with od... but needs the t-bar crossmember modified and a little tunnel work.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: DaveDudek]
#2537187
08/16/18 02:32 PM
08/16/18 02:32 PM
Posts: 1,542 USA
hudsonhornet7x
USA
Dave,
A small block 727 will bolt right up but you do need a special flexplate that Mopar performance sells. I believe there are other aftermarket choices as well.
Also, you have a pm on another matter. Thanks!
