70 T/A carb hose routing question #2536444
08/14/18 10:01 PM
08/14/18 10:01 PM
The Grand State of Confusion-O...
SKR8PN Offline OP
SKR8PN  Offline OP
I have a 70 T/A in the shop for a center carb replacement. The carb that is on the car has a red vacuum plug sealing up the vent. The new carb has a black hose attached from Holley. My question is, what does that hose go to? I see nothing on the car that it could plug into......
Karma has no menu. You get served what you deserve.
Re: 70 T/A carb hose routing question [Re: SKR8PN] #2536445
08/14/18 10:04 PM
08/14/18 10:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Vent open except when coded N95.
If it has N95, hose to a nipple on the three nipple valve cover breather.
Re: 70 T/A carb hose routing question [Re: SKR8PN] #2536448
08/14/18 10:04 PM
08/14/18 10:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Original FY4 car? Fairly scarce if so.
Re: 70 T/A carb hose routing question [Re: Alaskan_TA] #2536455
08/14/18 10:12 PM
08/14/18 10:12 PM
SKR8PN Offline OP
SKR8PN  Offline OP
No 3 nipple on the valve cover and yes on the color as well as an automatic. Will check the code.....
Re: 70 T/A carb hose routing question [Re: SKR8PN] #2536456
08/14/18 10:14 PM
08/14/18 10:14 PM
SKR8PN Offline OP
SKR8PN  Offline OP
n 94 code
Re: 70 T/A carb hose routing question [Re: Alaskan_TA] #2536550
08/15/18 01:13 AM
08/15/18 01:13 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Barry I think you got that one wrong.
If it's a N95 it goes to a 3 nipple breather
If it's NOT a N95 it goes to a 2 nipple breather
There are no CA 340 SIXPACK carbs
Re: 70 T/A carb hose routing question [Re: Morty426] #2536558
08/15/18 01:43 AM
08/15/18 01:43 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
N95 got a 3 nipple, the rest got a single nipple breather.
The hose from the large outlet on the breather is connected to a tube on the air cleaner base.
This is my car with a single nipple breather and a picture I saved of a member's N95 car.
Re: 70 T/A carb hose routing question [Re: Mastershake340] #2536563
08/15/18 01:56 AM
08/15/18 01:56 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Shake
Where does your bowl vent go?
Re: 70 T/A carb hose routing question [Re: Morty426] #2536565
08/15/18 02:00 AM
08/15/18 02:00 AM
Crook County, ILL
Crook County, ILL
Vents to atmosphere. No hose.
Re: 70 T/A carb hose routing question [Re: Mastershake340] #2536574
08/15/18 02:44 AM
08/15/18 02:44 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, vents to atmosphere, but never liked that on any of my sixpack cars, I always capped the bowl vent tube, no need to have a possible fuel leak/fire that could have been avoided...
Re: 70 T/A carb hose routing question [Re: Mastershake340] #2536575
08/15/18 02:44 AM
08/15/18 02:44 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Well what do you know ... learned something new today
Re: 70 T/A carb hose routing question [Re: Morty426] #2536594
08/15/18 08:24 AM
08/15/18 08:24 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The two nipple breather for 1970 has one application - /6 engines with N95.
Re: 70 T/A carb hose routing question [Re: SKR8PN] #2536595
08/15/18 08:27 AM
08/15/18 08:27 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
N94 is the Trans Am package.
No N95 present, so you need a single nipple breather connected to the air cleaner base & leave the vent open to be factory correct.
Re: 70 T/A carb hose routing question [Re: SKR8PN] #2536714
08/15/18 01:06 PM
08/15/18 01:06 PM
WA
tman Offline
tman  Offline
WA
Does this info apply to 1970 440-6 ebody?
Re: 70 T/A carb hose routing question [Re: tman] #2536767
08/15/18 02:44 PM
08/15/18 02:44 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yes and no.
The non-California center carb does not have a nipple on it, it has a bowl vent.
So non-CA uses a single nipple breather and CA the 3 nipple breather
Re: 70 T/A carb hose routing question [Re: SKR8PN] #2536771
08/15/18 02:51 PM
08/15/18 02:51 PM
SKR8PN Offline OP
SKR8PN  Offline OP
Thanks tons for the info and the pictures. This car is soooo nice that I am going to also plug the bowl vent with a black, fuel capable plug and not that red vacuum plug. I am also very nervous about just letting it vent to atmosphere. I will just be sure to show the owner what I did and why.
I am replacing the center carb for one with the correct numbers. The one that was on the car was for a 4 speed car. Also, whoever installed these carbs was a hack. He had screwed up the flare nut on the rear line right at the carb inlet so bad that I had to make a replacement line. It looked like he installed it with a pipe wrench. :0
Re: 70 T/A carb hose routing question [Re: SKR8PN] #2536860
08/15/18 07:12 PM
08/15/18 07:12 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Valve cover breather 101 for all 1970 model year engines;
Single nipple - all /6 & V8 engines without N95.
Dual nipple - All /6 engines with N95.
Triple Nipple - All V8 engines with N95.
Re: 70 T/A carb hose routing question [Re: SKR8PN] #2536993
08/16/18 01:07 AM
08/16/18 01:07 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Hey the factory had that bowl vent to atmosphere for a reason - I would not put a plug on it
Re: 70 T/A carb hose routing question [Re: SKR8PN] #2537022
08/16/18 03:37 AM
08/16/18 03:37 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Nervous? Fuel leak? How do you plug the bowl vent on a 440-6 non N95 with the flapper valve?
Re: 70 T/A carb hose routing question [Re: Morty426] #2537033
08/16/18 07:21 AM
08/16/18 07:21 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've been plugging (capping) the vent (tube style)for decades, dosen't effect operation/performance....
Mike
