Page 1 of 3 1 2 3
Need help tuning dominator for the street #2536123
08/14/18 12:50 PM
08/14/18 12:50 PM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
I have a 1050 holley hp 3 circuit dominator on my 526 wedge that is very rich trying to drive on the street. The engine was dynoed with the carb and was great at wide open throttle but on the street it paints the plugs black in 10 miles. It is a prosystems carb. They had me take the intermediate air bleeds out and it is still really rich. I have the timing locked at 35 degrees. It has 11:1 comp. hydraulic roller with 270 duration at .050 and Indy little ez 295 heads. Any help would be appreciated
Thanks Brandon.
Re: Need help tuning dominator for the street [Re: Canam800] #2536148
08/14/18 01:46 PM
08/14/18 01:46 PM
You need to have it work on by someone competent unless you know the circuits and have the tools needed to modify it work
That plugs would make me want to lean out the transition fuel feed circuit only by 30 to 40 percent twocents
To do that you need a good set of numbered drill bits, #1 to #70, a good pin vise to hold the bits and a good set of taps and dies down to #4 size. I use brass #6x32 set screws to modify the carbs to lean those circuits down up
If you don't have those tools or don't want to do the work yourself try contacting Dominic, Thumperdart, on here and have him do it for you scope twocents
Re: Need help tuning dominator for the street [Re: Canam800] #2536150
08/14/18 01:47 PM
08/14/18 01:47 PM
an8sec70cuda Offline
Have you contacted Patrick at Pro Systems about it? If not, that's where I'd start.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Need help tuning dominator for the street [Re: Canam800] #2536195
08/14/18 03:03 PM
08/14/18 03:03 PM
PA
Harry's Taxi 2 Offline
PA
I would (and did) start reading here....pay particular attention to jmark and tuner. https://www.tapatalk.com/groups/racingfuelsystems/index.php
pro systems is good at promotion and not much else.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Need help tuning dominator for the street [Re: Canam800] #2536204
08/14/18 03:18 PM
08/14/18 03:18 PM
AndyF Offline
AndyF  Offline
Plug the intermediate circuit and see what that does. Don't go WOT like that, just fire it up and drive it a bit at part throttle. If that solves it then you know that you need to lean the intermediate way down. Back when I used a 3 circuit carb I had to take about 80% of the intermediate jetting out of the carb to get it to work.
You shouldn't use a 3 circuit on the street since at part throttle you'll have a lot of suction against the intermediate dump tube and it will pull extra fuel into the engine. You're best bet is to convert that carb over to a two circuit or else just lean the intermediate circuit down until it isn't killing the engine.
Do your metering blocks have jets for the intermediate circuit? If so you can easily change the jets. If you have an older carb without jets then you probably need to buy new metering blocks. Otherwise it will just be a pain to do all of the jetting work that you're going to need to do.
Re: Need help tuning dominator for the street [Re: Canam800] #2536230
08/14/18 03:57 PM
08/14/18 03:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I've converted many to 2 circuits for street use, boat and even a drag week winner on here Ray Meyers...........Easy, not too expensive and VERY street-able when I'm done......... thumbs
Re: Need help tuning dominator for the street [Re: Canam800] #2536288
08/14/18 05:43 PM
08/14/18 05:43 PM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
Here is the spec sheet that came with the carb. The picture of the plug is with the intermediate air bleeds completely removed. Can I change anything to make it work or do I have to change it to a 2 circuit? Thanks for your help
Brandon
Re: Need help tuning dominator for the street [Re: Canam800] #2536296
08/14/18 05:53 PM
08/14/18 05:53 PM
AndyF Offline
AndyF  Offline
Replace the 0.040 intermediate fuel jets with 0.020 jets. That will knock 75% of the fuel out of the intermediate circuit. That should be a good starting point. Drive it a bit, see how it does and go from there. Do not go WOT until you have a good handle on what it is doing.
You might want to put a power valve in the front and jet down to 84 or so. That carb looks like it is set up for drag race only. Driving it on the street will kill your rings and eventually take the whole engine with it.
Re: Need help tuning dominator for the street [Re: Canam800] #2536344
08/14/18 07:13 PM
08/14/18 07:13 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’d def put a primary PV in it and take out some jet.
I’d try increasing the iab as well....... and see if there are any transfer slot restrictors in the main body.
Re: Need help tuning dominator for the street [Re: Canam800] #2536372
08/14/18 07:55 PM
08/14/18 07:55 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Besides the carb, having the timing locked at 35 isn't doing the motor any favors on the street, I would think...
Re: Need help tuning dominator for the street [Re: Canam800] #2536475
08/14/18 10:44 PM
08/14/18 10:44 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Only thing my Pro Systems 950HP (I know not a dominator, but still carb) was good at was WOT, pig rich at idle, it sucked, nothing would work.
Thumper fixed it and then some.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Need help tuning dominator for the street [Re: Canam800] #2536486
08/14/18 11:24 PM
08/14/18 11:24 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Thumper really is your best bet.
Master, again and still
Re: Need help tuning dominator for the street [Re: Harry's Taxi 2] #2536498
08/14/18 11:44 PM
08/14/18 11:44 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
up Make it even easier. Start with thse two at RFS for the how and why.
Tuning 1050 Dominator
Evolution and use of 2 circuit 1050 Dominators
Re: Need help tuning dominator for the street [Re: Canam800] #2536520
08/15/18 12:11 AM
08/15/18 12:11 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Sounds like it needs to be Thumped whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Need help tuning dominator for the street [Re: Canam800] #2536544
08/15/18 12:57 AM
08/15/18 12:57 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I don't run a Dominator but I agree about leaning out or taking out the intermediate circuit. I will say on my 850 DP I jetted it for mph at the track and found out it was a tad rich when at part throttle cruise. So I just dropped my primary main jest a tad and then opened up my primary power valve channels to make the fuel up at full throttle. I only dropped the primary main jets a little but it made a big difference when cruising at part throttle. Cleaned it up just right and plugs look much better. Ron
Re: Need help tuning dominator for the street [Re: Canam800] #2536552
08/15/18 01:21 AM
08/15/18 01:21 AM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
Well I gues it needs to be converted to a 2 cuircut. I sent it out to them so that I could use it on the street which is where it will be used 99% of the time. that didn't work. Do you know what kind of jets are used for the intermediate circuit? I could put the 20 jets in. Would it be ok to drive like 30 miles with the 20's? I wanted to take the car to a show this weekend and wouldn't have the carb back in time if I sent it out tomorrow. Also as far as the timing is it not good for the street to have it locked? I thought it would be better with my cam. I have 1.6 rockers Here is my cam card. Thanks Brandon
Re: Need help tuning dominator for the street [Re: Canam800] #2536626
08/15/18 10:20 AM
08/15/18 10:20 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Your cam is very close to what i have in my 511, but flat tappet. Works great. I had 2 prosystems carbs in the past. Not impressed. Dom at Thumpercarbs will give you the most time on the phone getting that thing dialed. My 1150 was near perfect right out of the box. All carbs get tested on his 470 before shipping.
Re: Need help tuning dominator for the street [Re: Canam800] #2536638
08/15/18 10:52 AM
08/15/18 10:52 AM
I'm just gonna say that Pro Systems did the 1200 cfm 3 circuit Dominator that's on my street/strip hemi and it's been great since 2006. No need to convert to 2 circuit if the 3 circuit is done correctly.
If I need another one done, Pro Systems will get my business.
CHIP
Re: Need help tuning dominator for the street [Re: Canam800] #2536675
08/15/18 11:58 AM
08/15/18 11:58 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
If you want to drive it 30 miles immediately, stick a power valve in it and the drop the primary jets down. I can't say for sure what the motor will like but I'd think you want to down to 84 or 86 jets.
You have a 6.5pv laying around??
Re: Need help tuning dominator for the street [Re: Canam800] #2536685
08/15/18 12:12 PM
08/15/18 12:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
What took everyone so long?
Boffin Emeritus
Page 1 of 3 1 2 3
