Re: Need help tuning dominator for the street
[Re: Canam800]
#2536150
08/14/18 01:47 PM
08/14/18 01:47 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Have you contacted Patrick at Pro Systems about it? If not, that's where I'd start.
[Re: Canam800]
#2536195
08/14/18 03:03 PM
08/14/18 03:03 PM
Posts: 287 PA
Harry's Taxi 2
PA
I would (and did) start reading here....pay particular attention to jmark and tuner. https://www.tapatalk.com/groups/racingfuelsystems/index.phppro systems is good at promotion and not much else.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Canam800]
#2536344
08/14/18 07:13 PM
08/14/18 07:13 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d def put a primary PV in it and take out some jet.
I’d try increasing the iab as well....... and see if there are any transfer slot restrictors in the main body.
[Re: Canam800]
#2536475
08/14/18 10:44 PM
08/14/18 10:44 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Only thing my Pro Systems 950HP (I know not a dominator, but still carb) was good at was WOT, pig rich at idle, it sucked, nothing would work.
Thumper fixed it and then some.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Canam800]
#2536486
08/14/18 11:24 PM
08/14/18 11:24 PM
Posts: 12,092 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Thumper really is your best bet.
Master, again and still
[Re: Canam800]
#2536552
08/15/18 01:21 AM
08/15/18 01:21 AM
Posts: 63 Lanse,mi
Canam800
Lanse,mi
Well I gues it needs to be converted to a 2 cuircut. I sent it out to them so that I could use it on the street which is where it will be used 99% of the time. that didn't work. Do you know what kind of jets are used for the intermediate circuit? I could put the 20 jets in. Would it be ok to drive like 30 miles with the 20's? I wanted to take the car to a show this weekend and wouldn't have the carb back in time if I sent it out tomorrow. Also as far as the timing is it not good for the street to have it locked? I thought it would be better with my cam. I have 1.6 rockers Here is my cam card. Thanks Brandon
[Re: Canam800]
#2536638
08/15/18 10:52 AM
08/15/18 10:52 AM
an8sec70cuda
I'm just gonna say that Pro Systems did the 1200 cfm 3 circuit Dominator that's on my street/strip hemi and it's been great since 2006. No need to convert to 2 circuit if the 3 circuit is done correctly. If I need another one done, Pro Systems will get my business.
[Re: Canam800]
#2536685
08/15/18 12:12 PM
08/15/18 12:12 PM
Posts: 4,206 New York
polyspheric
New York
You might want to put a power valve in the front and jet down to 84 or so
What took everyone so long?
Boffin Emeritus
