Re: 2001 V-10 transmission ?
[Re: moparx]
#2536275
08/14/18 05:14 PM
08/14/18 05:14 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
it is a 47re trans , so it depends on inputs from governor sensor and tps and speed sensor and others to determine shift strategy, so yes it does need a tcm to control it, Im sure someone has developed something I just don't know who
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: moparx]
#2536349
08/14/18 07:22 PM
08/14/18 07:22 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The TFOD-3 is a manual shift conversion and therefore bypasses the governor and speed sensor control but still needs electrical input for OD and lockup.
[Re: moparx]
#2536434
08/14/18 09:46 PM
08/14/18 09:46 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Are you planing on using it behind a v10? The bell housing wont fit a v8 if that is the plan.
[Re: moparx]
#2536605
08/15/18 09:09 AM
08/15/18 09:09 AM
Posts: 20,660 in a cattle trailer down by th...
Guitar Jones
CRT has full manual shift trans brake valve bodies for them. Manual control of 1st, 2nd, 3rd and O/D. You can have lockup too on a switch.
