2001 V-10 transmission ? #2536100
08/14/18 12:02 PM
08/14/18 12:02 PM
moparx Offline OP
moparx  Offline OP
would the transmission behind a 2001 V-10 in a 2500 2wd pickup be an A518 ? if so, would a forward pattern trans-go TFOD-3 race/manual shift kit still require the computer to operate correctly ? as always, TIA. bow
beer
Re: 2001 V-10 transmission ? [Re: moparx] #2536275
08/14/18 05:14 PM
08/14/18 05:14 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
it is a 47re trans , so it depends on inputs from governor sensor and tps and speed sensor and others to determine shift strategy, so yes it does need a tcm to control it, Im sure someone has developed something I just don't know who
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: 2001 V-10 transmission ? [Re: moparx] #2536349
08/14/18 07:22 PM
08/14/18 07:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The TFOD-3 is a manual shift conversion and therefore bypasses the governor and speed sensor control but still needs electrical input for OD and lockup.
Re: 2001 V-10 transmission ? [Re: John_Kunkel] #2536432
08/14/18 09:42 PM
08/14/18 09:42 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
Better off with a 47 rh
Re: 2001 V-10 transmission ? [Re: moparx] #2536434
08/14/18 09:46 PM
08/14/18 09:46 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Are you planing on using it behind a v10? The bell housing wont fit a v8 if that is the plan.
Re: 2001 V-10 transmission ? [Re: moparx] #2536605
08/15/18 09:09 AM
08/15/18 09:09 AM
Guitar Jones Offline
CRT has full manual shift trans brake valve bodies for them. Manual control of 1st, 2nd, 3rd and O/D. You can have lockup too on a switch.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 2001 V-10 transmission ? [Re: Guitar Jones] #2536683
08/15/18 12:08 PM
08/15/18 12:08 PM
moparx Offline OP
moparx  Offline OP
thanks guys ! was considering this as a possible core transmission, with changing out the bell to a JW unit. also considering a cope valve body. using the trans-go kit, would the electrical input needed be like that on a 47RH, and could that be done with toggle switches ? not much to be had around these parts in a 47RH core, and i really don't want to travel a couple hundred miles to pick one up. the one i'm asking about is a good transmission, but it's been on the local junkyard's shelf for a looong time, hence the core price of $100.00. other thoughts ?
beer
Re: 2001 V-10 transmission ? [Re: moparx] #2536695
08/15/18 12:27 PM
08/15/18 12:27 PM
moparx Offline OP
moparx  Offline OP
john kunkle answered my question. switches can be used to engage OD and lockup.
beer
