Re: Pcv grommet for M/T valve covers
[Re: General 68]
#2532211
08/06/18 11:44 AM
08/06/18 11:44 AM
Posts: 200 Maryland
mrob
Maryland
I've used these with the Mopar Performance cast aluminum valve covers before and they work. Your M/T valve covers are probably about the same thickness, so it should work with them as well, so take a look: https://www.summitracing.com/parts/dcc-5249642/overview/Note: You will need to use the stock Mopar PCV valve with this grommet.
[Re: General 68]
#2532571
08/06/18 11:32 PM
08/06/18 11:32 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Could be worth a shot, especially if you can buy without an exorbinant shipping fee. Don't recall trying any with a p/n that high. I tried some other MP ones and they didn't work. The proper ones were sold by Holley - and may not be in production. Photos and p/n posted here. https://board.moparts.org/ubbthreads/ubbt...tml#Post2203086
[Re: General 68]
#2532572
08/06/18 11:35 PM
08/06/18 11:35 PM
Posts: 1,487 STL
cdstl
STL
That was my thread. I ended up getting a rubber "plug" that said oil on it and then I bored a hole until it fit the PCV valve.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: General 68]
#2536138
08/14/18 01:17 PM
08/14/18 01:17 PM
Posts: 1,487 STL
cdstl
STL
Because I am an idiot, I deleted the link that I found for the Dorman breather grommet. Does anyone know which one it is? I have the link to the Dorman PCV grommet. https://www.google.com/search?q=dorman+4...me&ie=UTF-8
