Pcv grommet for M/T valve covers #2532163
08/06/18 07:50 AM
08/06/18 07:50 AM
Norway
General 68 Offline OP
Norway
I have been searching without finding what pcv grommet to get for M/T alu valve covers. The grommet for stamped steel covers won't work as the groove in them is not wide enough. Any parts number or car model to refer to?
Re: Pcv grommet for M/T valve covers [Re: General 68] #2532211
08/06/18 11:44 AM
08/06/18 11:44 AM
Maryland
mrob Offline
mrob  Offline
Maryland
I've used these with the Mopar Performance cast aluminum valve covers before and they work. Your M/T valve covers are probably about the same thickness, so it should work with them as well, so take a look:
https://www.summitracing.com/parts/dcc-5249642/overview/
Note: You will need to use the stock Mopar PCV valve with this grommet.
Re: Pcv grommet for M/T valve covers [Re: General 68] #2532571
08/06/18 11:32 PM
08/06/18 11:32 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Could be worth a shot, especially if you can buy without an exorbinant shipping fee. Don't recall trying any with a p/n that high. I tried some other MP ones and they didn't work.
The proper ones were sold by Holley - and may not be in production. Photos and p/n posted here.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2203086
Re: Pcv grommet for M/T valve covers [Re: General 68] #2532572
08/06/18 11:35 PM
08/06/18 11:35 PM
STL
cdstl Offline
cdstl  Offline
STL
That was my thread. I ended up getting a rubber "plug" that said oil on it and then I bored a hole until it fit the PCV valve.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Pcv grommet for M/T valve covers [Re: General 68] #2532595
08/07/18 12:32 AM
08/07/18 12:32 AM
missouri,usa
cryplydog Offline
cryplydog  Offline
missouri,usa
Check out mancini racing and look at the Dims. on bb and sb. If I remember correctly I had to choose some from the sb section in order to fit.
Re: Pcv grommet for M/T valve covers [Re: General 68] #2536138
08/14/18 01:17 PM
08/14/18 01:17 PM
STL
cdstl Offline
cdstl  Offline
STL
Because I am an idiot, I deleted the link that I found for the
Dorman breather grommet. Does anyone know which one it is?
I have the link to the Dorman PCV grommet.
https://www.google.com/search?q=dorman+4...me&ie=UTF-8
