Engine lost some power and stall rpm’s. #2535954
08/14/18 12:39 AM
08/14/18 12:39 AM
sg66mopar Offline OP
I need some help from my smarter than me racing friends. I had a delay box failure a couple races back that caused the car to not shift and subsequently over rev the engine. After I fixed the box problem everything seemed OK with the engine but the car was sluggish and lost a bunch of ET. I have a 5100 rpm launch chip and my converter would normally stall at about 5700 in the air we have here. The first few passes after fixing the box the starting line rpm was around 4500. Every couple passes it increased a little until our last run, when it stalled at just over 5000. The car got closer what it should be running but it’s still slow. Help?
Re: Engine lost some power and stall rpm’s. [Re: sg66mopar] #2535956
08/14/18 12:45 AM
08/14/18 12:45 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Horsepower affects stall. Leak-down the engine to see if possibly you bent some valves when you over reved the engine.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Engine lost some power and stall rpm’s. [Re: sg66mopar] #2535962
08/14/18 12:52 AM
08/14/18 12:52 AM
Washington
madscientist Offline
Washington
What PBR said or you had a fluke deal and lost a converter.
Re: Engine lost some power and stall rpm’s. [Re: sg66mopar] #2536453
08/14/18 10:08 PM
08/14/18 10:08 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I just went through the same thing. Found a broken rocker. I’d check the springs too.
Re: Engine lost some power and stall rpm’s. [Re: humpty] #2536460
08/14/18 10:22 PM
08/14/18 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure your timing is correct(easy thing
to check then a compression check
wave
Re: Engine lost some power and stall rpm’s. [Re: sg66mopar] #2536495
08/14/18 11:39 PM
08/14/18 11:39 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
My cousin did the over rev thing on his car once. It sounded good but ran weak after that. Compression check showed low compression, he'd knicked all the intake valves.
