Re: Hemi rubber tubing?
[Re: robertop]
#2535938
08/14/18 12:13 AM
08/14/18 12:13 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I am trying to find some place to get a piece of engine rubber tubing, maybe not specific to a Hemi car. This tubing is 3/8" with 3 ribs and connects the back of the carb base plate with the small steel line that starts at the RH manifold and runs in the back of the engine. This for a 69 Hemi roadrunner; could not find it in any of my catalogs. Thanks for any lead, guys. I'll assume your "3/8" is the OD of the tubing?....perhaps it's the ribbed vacuum hose your after? R.Gibson has some...
[Re: robertop]
#2536716
08/15/18 01:08 PM
08/15/18 01:08 PM
Posts: 21,446 It's a dry heat
gtx6970
It's a dry heat
The hose your after. Is it 3/8" OD or ID ?
[Re: robertop]
#2537562
08/17/18 11:14 AM
08/17/18 11:14 AM
Posts: 18,157 Mass
DAYCLONA
Mass
You are right, there is nothing special about the diameter, however the rub is with the 3 ribs that make it very hard to find...... I'm surprised Gibson didn't have that?...
