Page 2 of 3 1 2 3
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535496
08/13/18 09:51 AM
08/13/18 09:51 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Dizusters 360 turbo car can easily run 9.80s@ 3750lbs, 3.55 gear, drag radials.
Doug
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535503
08/13/18 10:00 AM
08/13/18 10:00 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What's the budget for this effort?
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: BradH] #2535505
08/13/18 10:13 AM
08/13/18 10:13 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
12 to 15,000$ I would think
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535519
08/13/18 10:57 AM
08/13/18 10:57 AM
an8sec70cuda Offline
Your typical B body like you're describing will likely be around 3700-3800 lbs. You'll need a REAL 825+ HP at the flywheel to run the number you want.
You can build a stout, but streetable, 512 and hit it w/ a 200 shot every now and then to go mid 9s.
Or go big or go home w/ the 512 and put some decent compression in it, E 85, and bigger heads than the Trick Flows, nasty roller and try to go mid 9s on motor. Either way, the stock block will be a time bomb.
Or do like I did and get a strong aftermarket block and build a big, but streetable, 572" motor that'll run mid 9s all day at 3800 lbs on pump gas.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535526
08/13/18 11:09 AM
08/13/18 11:09 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Assuming it's a stock car, but with appropriate chassis and wheel/tire upgrades to handle the extra power, I would think you will need at least 850hp to get you mid 9s. Late 90's I ran mid 10s in a stock steel body and full interior 68 charger. Had a Indy headed 451 that made about 730hp. No cage, 8 3/4 w 4.30 spool, 5200 converter, 8" steel wheels w ET streets.
2 kids and a dog
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: TonyS451] #2535772
08/13/18 06:44 PM
08/13/18 06:44 PM
my own world
theraif Online tonguue
theraif  Online Tonguue
my own world
find his combo and copy it boogie
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535794
08/13/18 07:25 PM
08/13/18 07:25 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looked at a few numbers today.
The correction factor from sea level to 5000’ is about 1.05 for ET, so a 9.50 is close to a 10.0 @5000’.
The Moroso chart shows 825hp for a 9.50@3800lbs, and “most” cars need about 10% more power than indicated to get it done.
I’d be shooting for 900hp if that’s really the target ET.
Less weight = less power req’d.
Basically, that ET is about 4.6lbs/hp if the car is sorted out.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: fast68plymouth] #2535803
08/13/18 07:39 PM
08/13/18 07:39 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
Here is a picture of my 70 GTX which is same body as 70 RR.
It has a Chenoweth built 493 stroker with Indy SR heads. You will need more with all the street goodies on the RR.
MJ
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535815
08/13/18 07:58 PM
08/13/18 07:58 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
A motor combo in another thread is a good thing point:
Who has a good cam recommendation for a 572 with indy 345 cnc 2.25 intake 181 exhaust heads. Indy tunnel ram with to alky 750 carbs. 14.1 compression with diamond flat tops. 4.500 bore 4.500 stroke.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: Clanton] #2535851
08/13/18 09:14 PM
08/13/18 09:14 PM
CO
crankn101 Offline OP
CO
I dont really have a budget, I was hoping for 10-12K for the engine or so plus whatever power adder I go with.
From the sounds of it, I might build this to a 10.5 street car and pick up a lighter car for racing.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: moparjohn] #2535852
08/13/18 09:15 PM
08/13/18 09:15 PM
CO
CO
MJ
NA?
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535862
08/13/18 09:31 PM
08/13/18 09:31 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
MJ
NA?
Yes, 1050 carb with Indy intake.
MJ
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535915
08/13/18 11:24 PM
08/13/18 11:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
[quote=BradH]What's the budget for this effort?
From the sounds of it, I might build this to a 10.5 street car and pick up a lighter car for racing. [/quote}
10-12K isn't even close with new parts for a 900 hp 572. Mine was built from a combo of used and new. If all the parts were new it would be close to 20K. It'll run 9.20@145 at 4500 D/A, 9.0@150 at 1200 D/A. A dominator and single 4 might be a little quicker. 3340 race ready. The Turbo Late Hemi or SB stuff should get it done cheaper.
Doug
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535928
08/13/18 11:58 PM
08/13/18 11:58 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Doug, I drool every time I see that pic.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535933
08/14/18 12:05 AM
08/14/18 12:05 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The easiest, best, AND cheapest way would be with one or more turbos. Especially if you want to actually be able to drive it on the street too.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: theraif] #2535970
08/14/18 01:10 AM
08/14/18 01:10 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Haha, yeah, not Mopar under the hood...
'63 Dodge 330
11.19 @ 121 mph
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: dvw] #2535974
08/14/18 01:20 AM
08/14/18 01:20 AM
CO
CO
Doug
For the record, building a 572 or an after market block was never in any of my plans.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535978
08/14/18 01:29 AM
08/14/18 01:29 AM
CO
CO
This was linked to me from some where, but I cant find who posted it. Anyways, what about a setup close to this with a 512" motor and EFI?
https://www.hotrod.com/articles/mopp-0604-440-mopar-engine-build/
And I also read these original blocks can hold more power if the engine is "boosted", is that true?
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: GTX MATT] #2535981
08/14/18 01:31 AM
08/14/18 01:31 AM
CO
CO
What does someone charge to fab something like that up? I dont have the welding and fab skills for anything close to that.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2536027
08/14/18 07:29 AM
08/14/18 07:29 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
[quote=Clanton][quote=BradH]What's the budget for this effort?
I'd run a Late Hemi with a turbo. Stock block and forged crank will hold 1000 HP w/o issue. Stock heads are very good. aftermarket piston/rod for boost. Use a knock off Drag Pac intake. 20 psi should get it easy.
Doug
Page 2 of 3 1 2 3
