Page 1 of 3 1 2 3
Easiest and or best way to run a 9.5et 70' Roadrunner #2535206
08/12/18 06:38 PM
08/12/18 06:38 PM
CO
crankn101 Offline OP
CO
This is my first post here, be gentle...
I dont want to seem like Im looking for exact numbers and parameters to build an engine, Im just looking for general guidance for now.
What are some engine/tranny combos to get a 70' Roadrunner into the 9.5 1/4 mile range?
Im looking at building a 440/512 stroker (440 source) with an EFI system of some kind and Trickflow heads. But I am open to other options, Im here to learn.
Blow through supercharger? NOS?
If Im correct a blower motor should be built at around 8.5 compression, is that the same for a NOS motor?
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535227
08/12/18 07:26 PM
08/12/18 07:26 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
NOS will like 13:1.
We need to know more about your Road Runner, to know what it takes to run 9.50. Is it mostly stock now? Weight is a key factor. B bodies car weigh between 2800lbs and 4500lbs race ready.
69 GTX 68 Road Runner
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535228
08/12/18 07:31 PM
08/12/18 07:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Where do you plan on racing it?
Denver requires more effort than Jersey.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535234
08/12/18 07:36 PM
08/12/18 07:36 PM
AndyF Offline
AndyF  Offline
Is this a race car or a street car? If it is a race car then you just sort out the power to weight ratio and dial in the suspension. A street car needs a lot of power to run that kind of number since the car is heavy and the suspension isn't very good.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: fast68plymouth] #2535240
08/12/18 07:50 PM
08/12/18 07:50 PM
CO
CO
Breaking into the 9s in CO would be fine, 9.8ish.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: JERICOGTX] #2535244
08/12/18 07:53 PM
08/12/18 07:53 PM
CO
CO
Originally Posted By JERICOGTX
NOS will like 13:1.
I want to keep it mostly stock as far as weight goes I believe. Keep all sheet metal except for the hood and keep full interior.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: JERICOGTX] #2535245
08/12/18 07:54 PM
08/12/18 07:54 PM
CO
CO
NOS will like 13:1.
Very interesting, I had no idea.
Build an E85 car and add some NOS?
This is why Im asking these dumb questions.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535249
08/12/18 08:00 PM
08/12/18 08:00 PM
So. Burlington, Vt.
So. Burlington, Vt.
Guesstimate of car weight?
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: fast68plymouth] #2535253
08/12/18 08:09 PM
08/12/18 08:09 PM
CO
CO
I have no idea, I thought they would all be close. Right now it has no engine or tranny.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535269
08/12/18 08:27 PM
08/12/18 08:27 PM
So. Burlington, Vt.
So. Burlington, Vt.
As Andy said, if it’s a street/strip car, you’re going to need to make more power per pound than a dedicated race car.
9.8’s in Co(Denver) in a typical race weight street/strip car(3800lbs), you’ll need more power than a stock block will live a long happy life.
I’d be shooting for 850-ish “Standard corrected horsepower”.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: fast68plymouth] #2535273
08/12/18 08:31 PM
08/12/18 08:31 PM
CO
CO
I’d be shooting for 800+ “Standard corrected horsepower”.
Thanks man. Thats right where I was thinking I would need to be on the low end of the HP rating.
I know turbos make up for the thin air up here, does NOS act the same way?
For what its worth Im leaving CO here pretty soon for the midwest.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535302
08/12/18 09:18 PM
08/12/18 09:18 PM
Portland, Oregon
Digger73 Online rolleyes
Digger73  Online Rolleyes
Portland, Oregon
If it helps. My stripped and race ready 1970 Road Runner with light weight everything I could get my hands on. Fiberglass doors, fenders, hood, trunk lid, and Bumpers. Lexan for windows, aluminum dash, no interior, 10 point mild steel cage and, aluminum front hubs. Plastic seat aluminum heads, manifold, master cylinder, and radiator. Dana 60 with split mono leafs, Torsion bars in front and, stock K frame. 200Lbs driver and 5 gallons of fuel = 2850Lbs. I was hoping to get 9.?? out of it with a very healthy 500" stroker.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535330
08/12/18 10:07 PM
08/12/18 10:07 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Count on not getting it right the first time, and shoot for 1,000 at least as to the hard structural parts.
Starting from scratch with minimal in-house fabrication capacity, I'd try a big Procharger and 200 nitrous.
Boffin Emeritus
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: polyspheric] #2535357
08/12/18 11:01 PM
08/12/18 11:01 PM
CO
CO
I understand, but I really want to get the bottom end and heads correct the 1st time, I dont want to waste that much money.
What size Procharger? F1? Im fairly certain I cant drop the coin for one of their race versions.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535370
08/12/18 11:28 PM
08/12/18 11:28 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
What your asking to achieve is going to take a few $$, your going to need 800++ HP and the suspension to help make it happen.
I have been playing big blocks on and off the strip for many years.
Im running a stock block 547, Indy topped with tunnel ram in my street 71 Barracuda that comes in at 3750 lb, I have not gone 9 yet, managed a 10.1 @ 135.
I have just changed the converter to a new 5000 and the rear shocks to Viking double adjustable in the hope of running that 9
Im no turbo guru but maybe that is your answer cause I know that doing it with just carbs is not that easy or cheap.
Good luck.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: ozymaxwedge] #2535395
08/13/18 12:27 AM
08/13/18 12:27 AM
CO
CO
Good luck.
Well, NA is a lot harder. If what Im reading is correct you should be able to run low 9s with a power adder of some kind?
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535452
08/13/18 03:20 AM
08/13/18 03:20 AM
Good luck.
Well, NA is a lot harder. If what I'm reading is correct you should be able to run low 9s with a power adder of some kind?
If your lucky and skillful work shruggy
Getting the mass moving quickly and efficiently is the hard part of getting a real quick 60 ft. time so it will make the high to mid nine ET in the 1/4 mile like your wanting, it will probably need to be in the mid 1.30 or quicker in the 60 fts. shruggy
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535472
08/13/18 06:44 AM
08/13/18 06:44 AM
UK
rb446 Offline
rb446  Offline
UK
Plenty of ways to go, personally I would build a mild 650>750hp 572ci motor using TF270's or -1's (ported), use a $$$$ Indy block or similar aftermarket block as at 800+hp a stock block won't last too long, do it once. Then add NOS. It doesn't have to be 13:1CR, 11:1 will work and with the right cam still be premium pump gas friendly for the street, use 1 of Dominic's sorted dominators.
At say 3800lbs race weight you'll need 875 actual track hp to go 9.50@141. Use something like Mono leafs/caltracs and some good shocks, make sure your car is stiff enough to handle the mega torque you'll have....you should only need a 200>250 shot to achieve your goal...my 2c's.
We have a guy here in UK (Tig who is a member here) who runs a 3900lbs+ Challenger with a 572 NA motor, street car interior with stereo at I believe 11.1 last time I spoke to him, .730 Roller, Caltracs/4.10's/29.5" slicks and a single Dom, has run a best of 9.6@140+, currently running 2 x Doms and 572-13's and running 9.7's still needing a bit of sorting I think.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535487
08/13/18 08:55 AM
08/13/18 08:55 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You might want to talk to an8sec70cuda (Chip). He has a stock weight 70 'Cuda with a KB 572 that runs 9's on motor, 8's on spray. It's a street car. He has his combo figured out very well and can probably give you some pointers on the suspension and drivetrain. You would need the same, if not more power out of your engine, and like previously stated, a stock block will not live long in that environment.
[image][/image]
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2535493
08/13/18 09:43 AM
08/13/18 09:43 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Welcome to Moparts!Going low 10.0 is not that hard but that other 1/2 sec is going to be tough.
Page 1 of 3 1 2 3
