What is this aluminum dual point distributor?
#2535149
08/12/18 04:55 PM
08/12/18 04:55 PM
Posts: 2,256 IL
furious70
IL
b block size, no tag or stampings I can find
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: What is this aluminum dual point distributor?
[Re: furious70]
#2535265
08/12/18 08:23 PM
08/12/18 08:23 PM
Posts: 797 WA
pro451bee
WA
[Re: furious70]
#2535611
08/13/18 01:47 PM
08/13/18 01:47 PM
RapidRobert
the lower shaft is 3&1/2"? (B size). the condensor looks new(er) & the points likely are. check how much side to side play the top shaft has (point tension wears the bushings way faster than electronic ones do). It'd be worth something to someone.
[Re: furious70]
#2536354
08/14/18 07:33 PM
08/14/18 07:33 PM
Posts: 2,256 IL
furious70
IL
someone emailed me and said it's a Mr Gasket Street Spark missing it's tag.
[Re: furious70]
#2536501
08/14/18 11:50 PM
08/14/18 11:50 PM
Posts: 2,256 IL
furious70
IL
Those are a little different, not a great photo, I'll need to compare them both next time I'm at the shop
