Brake expert needed. #2534590
08/11/18 02:35 PM
08/11/18 02:35 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
I converted my 68 Dart over to front disc brakes from a 1973 Duster system. The problem is when I pump the brakes fluid dumps out from under the cover. Leaks right under the rubber gasket. Fluid level about about 1/4" from top of reservoir. This is the second new master cylinder I put on and both did the same thing. Do I have a bad proportion valve? Never had this happen before, did this conversion many times. Brakes work fine. Lines all put on correctly, checked twice. Checking to see if this happened to anyone else.
Re: Brake expert needed. [Re: maximus] #2534593
08/11/18 02:47 PM
08/11/18 02:47 PM
s.d.
K
kermit1 Offline
kermit1  Offline
K
s.d.
i had this messy problem also with 2 rebuilt masters tried different covers that didnt help so i just purchased a NEW master and the issue was gone.i assume that maybe the top of the master cylinders maybe had imperfection in them from being dropped into core collecting barrels too many times.
Re: Brake expert needed. [Re: maximus] #2534595
08/11/18 02:50 PM
08/11/18 02:50 PM
moparx Online content
moparx  Online Content
did you look closely at the MC top sealing surface for any imperfections that could cause the gasket to leak ? check the gasket closely for tears ? look the top over for being straight ? loose, or wrong bail wire for lid ? just throwing stuff out there. i really don't think prop valve has anything to do with this.
beer
Re: Brake expert needed. [Re: maximus] #2534604
08/11/18 03:13 PM
08/11/18 03:13 PM
3
340clone Offline
340clone  Offline
Might be able to bend the cover wire to tighten the lid. I have had them loose enough to where you could slide the lid around...
Re: Brake expert needed. [Re: maximus] #2534610
08/11/18 03:33 PM
08/11/18 03:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If needed it isn't hard to sand that sealing surface flat.
Don't be the exception.
Re: Brake expert needed. [Re: Supercuda] #2534625
08/11/18 04:09 PM
08/11/18 04:09 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
You guys had to give my brain a kick start. I went out with a 3x5 block and some sandpaper. The top was flat but it had the cutter marks in the top surface. I sanded the top until all cutter grooves were gone. Put the top back on, pumped the heck out of the brakes and no more leak. Thanks for all your input.
Re: Brake expert needed. [Re: maximus] #2534646
08/11/18 04:47 PM
08/11/18 04:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Excellent
Re: Brake expert needed. [Re: maximus] #2535023
08/12/18 11:59 AM
08/12/18 11:59 AM
glad you got it "covered" up [pun intended biggrin]
beer
Re: Brake expert needed. [Re: moparx] #2535029
08/12/18 12:08 PM
08/12/18 12:08 PM
I'm glad somebody is in a good mood today
Re: Brake expert needed. [Re: RapidRobert] #2535031
08/12/18 12:14 PM
08/12/18 12:14 PM
what's going on today RR ? i'm just wore out from building a field stone wall the last couple of days. only have about 12 more rocks to cut and position. don't know if i can muster up the energy for that today or not.
beer
Re: Brake expert needed. [Re: moparx] #2535042
08/12/18 12:35 PM
08/12/18 12:35 PM
rest up for a day (you deserve it). Rome wasn't built in a day & mistakes can happen when we are tired/preoccupied. I'm gonna lay in bed & watch football all day.
Re: Brake expert needed. [Re: maximus] #2535117
08/12/18 03:54 PM
08/12/18 03:54 PM
BDW Offline
BDW  Offline
How did you keep the metal dust out of the brake fluid?
Re: Brake expert needed. [Re: BDW] #2535180
08/12/18 05:49 PM
08/12/18 05:49 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Looks like a majority of the dust stuck to the sandpaper. No visual dust in the fluid. Skimmed the top of the fluid with paper towel, no dust apparent. Shouldn't effect anything, I've seen heavy rust in old master cylinders in the past and they worked fine.
Re: Brake expert needed. [Re: maximus] #2535919
08/13/18 11:42 PM
08/13/18 11:42 PM
VA
dragon slayer Offline
VA
I am wondering why pumping the brakes makes fluid level rise in the MC. That is not suppose to happen. Once the compensating ports close it is a sealed system otherwise no pressure builds up. In fact the gasket/lid has an opening to atmosphere. Sure both front and back are working?
Re: Brake expert needed. [Re: dragon slayer] #2535921
08/13/18 11:45 PM
08/13/18 11:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It doesn't make the level rise. What happens is that until the fill ports are closes it will squirt a bit of fluid back into the reservoir. The faster/harder you hit the pedal the higher it will splash. If you ever bled brakes by pumping the pedal you seen it.
