Should a breather for a 70 340 A-Body have 2 or 3 nipples? #2534960
08/12/18 09:45 AM
08/12/18 09:45 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
What is the correct valve cover breather for a 1970 Dart with California emissions - 340 engine and 727 trans? Is it 2 or 3 nipples? The carburetor will be a standard Carter AVS. I know one of the small nipples is for the fuel line vapor, but not sure where the second small nipple goes to.
Re: Should a breather for a 70 340 A-Body have 2 or 3 nipples? [Re: vinnyd76] #2534965
08/12/18 09:54 AM
08/12/18 09:54 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
2 nipples for '70 /6 with N95.
3 nipples for '70 V8 engines with N95.
One small nipple to the carb vent port & one to the line on the inner fender for the V8s.
Re: Should a breather for a 70 340 A-Body have 2 or 3 nipples? [Re: vinnyd76] #2534992
08/12/18 11:05 AM
08/12/18 11:05 AM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
A body should only have two, if you have 3 something is wrong. J/k.
Re: Should a breather for a 70 340 A-Body have 2 or 3 nipples? [Re: vinnyd76] #2535007
08/12/18 11:25 AM
08/12/18 11:25 AM
I think to the tank via the line on the fender Alaskan mentioned
