Indy 440 EZ Heads with 67 440HP Exhaust Manifolds #2534702
08/11/18 06:35 PM
08/11/18 06:35 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Wondering if anyone has had any problems using stock port Indy EZ heads with 67 440HP exhaust manifolds, or other year HP manifolds for that matter. I did a mock up and looks like number 6 and 8 might be tight to fit a plug wire on because of the angle plugs. My concern is getting wires to work with this set up. Thanks.
RS23L7 4-Speed
Re: Indy 440 EZ Heads with 67 440HP Exhaust Manifolds [Re: Mopar_Mike] #2535102
08/12/18 03:21 PM
08/12/18 03:21 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Don't those manifolds defeat the purpose of using an aftermarket aluminum head.
Re: Indy 440 EZ Heads with 67 440HP Exhaust Manifolds [Re: Mopar_Mike] #2535173
08/12/18 05:37 PM
08/12/18 05:37 PM
AndyF Offline
AndyF  Offline
I think you are correct. Those plug wires will be right up against the manifold. You might get them to live if you use head shields of some sort.
Re: Indy 440 EZ Heads with 67 440HP Exhaust Manifolds [Re: jbc426] #2535261
08/12/18 08:20 PM
08/12/18 08:20 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don’t think the problem is necessarily “aftermarket aluminum heads” and ex manifolds, but I don’t think larger runner volumes along with ex manifolds are going to be the hot ticket.
The 84cc E street heads have straight plugs(no manifold issues), and the smaller runners are probably going to be better 90% of the time.
