360 passenger side motor mount
#2534065
08/10/18 06:34 AM
08/10/18 06:34 AM
Posts: 7 Louisiana
Jason73
Louisiana
I seem to see conflicting info on line. Does the motor mount on the passenger side go in front or behind the block tabs? This is on a 72 Challenger with a 360 magnum block. I have the correct brackets. It seems most people have problems with the drivers side so there a pics everywhere showing that side but no luck on the right side. I can’t seem to get the little stims on the mounts to drop in the slots so it will sit down flush on the K member, yet everything is bolted up. Any help is appreciated.
1972 challenger
Re: 360 passenger side motor mount
[Re: Jason73]
#2534133
08/10/18 12:31 PM
08/10/18 12:31 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Factory service manual shows how they go together. Get one. To the rear of the ears.
[Re: Jason73]
#2534241
08/10/18 03:52 PM
08/10/18 03:52 PM
Posts: 7 Louisiana
Jason73
Louisiana
Thanks. I guess I have them 9n correct. Both sides are on the back of the tabs. I wonder why i cant get the little spurs to drop down
1972 challenger
[Re: Jason73]
#2534248
08/10/18 04:02 PM
08/10/18 04:02 PM
Supercuda
About to go away
About to go away
up yours
You need to have all mounts loosely bolted on, including the trans mount, then wiggle the assembly till it drops into place.
When the factory assembled it the engine was installed into the K member along with the front suspension and what not then that whole assembly was bolted to the body.
