Page 8 of 10 1 2 6 7 8 9 10
Re: Super Sniper install [Re: AndyF] #2530484
08/02/18 02:07 PM
08/02/18 02:07 PM
central il.
second 70 Offline
second 70  Offline
central il.
I'm going to get more of the water neck spacers built. I sent a CAD file out for quotes so I should have parts on my website in a few weeks. [/quote]
Great Andy I'll take one.
Mike
Re: Super Sniper install [Re: AndyF] #2530517
08/02/18 03:10 PM
08/02/18 03:10 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Yep, I want one too Andy.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Super Sniper install [Re: AndyF] #2530549
08/02/18 04:51 PM
08/02/18 04:51 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Good deal! I'll have to keep an eye on the site and place an order.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Super Sniper install [Re: AndyF] #2530764
08/03/18 12:15 AM
08/03/18 12:15 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Can the base sniper efi be upgraded to the Super Sniper 650 with just a software program update to use it with nitrous or blow through?
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Super Sniper install [Re: AndyF] #2532634
08/07/18 02:24 AM
08/07/18 02:24 AM
AndyF Offline OP
AndyF  Offline OP
Re: Super Sniper install [Re: AndyF] #2532643
08/07/18 04:45 AM
08/07/18 04:45 AM
Calgary, AB
64Bel Offline
64Bel  Offline
Calgary, AB
Still creating a list for water neck spacers Andy? I'll take one.
Thanks!
Re: Super Sniper install [Re: 64Bel] #2532780
08/07/18 01:39 PM
08/07/18 01:39 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Thanks!
I'm in for a spacer too Andy, keep us posted.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Super Sniper install [Re: AndyF] #2533108
08/08/18 12:35 AM
08/08/18 12:35 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Was just looking at the Holley website, and the description for the Super Sniper 650 indicates "Progressive or Non-Progressive control strategies". Did they already add this feature for progressive throttle plates since the article was written/published, and have you tried a software update?
Re: Super Sniper install [Re: AndyF] #2533122
08/08/18 01:18 AM
08/08/18 01:18 AM
AndyF Offline OP
AndyF  Offline OP
I think that description on the website refers to nitrous control.
Holley marketing was very specific with me when I wrote the article. They do not want people using a progressive linkage on the Sniper.
Re: Super Sniper install [Re: AndyF] #2534420
08/11/18 12:24 AM
08/11/18 12:24 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Doh! Guess it was too much wishful thinking...
Re: Super Sniper install [Re: AndyF] #2534455
08/11/18 02:28 AM
08/11/18 02:28 AM
AndyF Offline OP
AndyF  Offline OP
I got the impression that support for a progressive throttle linkage will be coming along in a future release. Holley had progressive linkage on an earlier throttle body so they know how to do it, I guess they just left it off the first version of the Sniper.
Re: Super Sniper install [Re: AndyF] #2534520
08/11/18 11:55 AM
08/11/18 11:55 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Current Terminator throttle body use progressive linkage. I assume that price point, and limited space with the Sniper system are a few reasons for limited abilities.
If the sniper had all of the capabilities of the Terminator, no one would buy the higher end systems.
Re: Super Sniper install [Re: AndyF] #2537939
08/17/18 11:56 PM
08/17/18 11:56 PM
AndyF Offline OP
AndyF  Offline OP
I have the engine running with the Hyperspark ignition and so far it seems like an excellent upgrade over the MSD distributor that I had in there.
The Hyperspark ignition has full computer control so I can dial in whatever advance curve the engine needs. Idle performance and low speed driving really improved by adding a little more timing. With the MSD distributor I was limited to 16 degrees initial and 18 in the can for a total of 34. By getting rid of the mechanical setup now I can dial in whatever I want. I started off with 20 degrees at idle and kept the 34 at WOT. The few extra degrees at idle and low speed really smoothed the engine out. Manifold vacuum increased from 12 to 14 inches and the engine is using less fuel with the extra advance.
I still have a bunch more tuning to do but so far I'd say it is a major step forward.
Re: Super Sniper install [Re: AndyF] #2538556
08/19/18 02:22 PM
08/19/18 02:22 PM
AndyF Offline OP
AndyF  Offline OP
I've been out on the freeway driving the car and it is amazing how much less fuel the engine uses with the extra ignition timing. The MSD distributor that I had before did not have vacuum advance so I was limited to 34 degrees total going down the road. Now with 40+ degrees at cruise speed the fuel consumption is reduced by 30%. That is a big savings in gas. It was using around 40 lbs/hr at 75 mph and now it has dropped below 30 lbs/hr at the same speed. It isn't going to be a fuel economy star but now I should be able to take it somewhere without always having to look for a gas station. If I can get 15 mpg on the freeway I'd be happy. I typically don't drive it more than 30 or 40 miles anyway but maybe if the mpg is better I might take it on longer drives.
Re: Super Sniper install [Re: AndyF] #2538562
08/19/18 02:42 PM
08/19/18 02:42 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Andy, since there is no vacuum pod with the Hyperspark distributor I'd guess you manually add the extra timing for cruise? Or, are there a pre-determined curves built in for various situations? How is timing handled in general?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Super Sniper install [Re: AndyF] #2538621
08/19/18 06:40 PM
08/19/18 06:40 PM
AndyF Offline OP
AndyF  Offline OP
There is a timing table in the software which you can edit. Basically I have 19 at idle, 34 at WOT and 42 for freeway cruising and then smoothed out between those areas.
Re: Super Sniper install [Re: AndyF] #2538807
08/20/18 01:31 AM
08/20/18 01:31 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If you want to get really tricky with it you should be able to set up a lean burn timing/fuel curve scenario for light throttle cruising.
Kevin
Re: Super Sniper install [Re: AndyF] #2538999
08/20/18 01:18 PM
08/20/18 01:18 PM
AndyF Offline OP
AndyF  Offline OP
I added the digital dash and built a new console panel for analog gauges. Most of this is temporary, I'll figure out what I want long term in the car some other time. But for now I can watch the EFI sensors with the digital dash and I have duplicate analog gauges for the important stuff.
Re: Super Sniper install [Re: AndyF] #2540124
08/22/18 06:37 PM
08/22/18 06:37 PM
AndyF Offline OP
AndyF  Offline OP
Got some runs on the chassis dyno today. Made 485 rwhp and 525 ft-lbs. Not bad for pump gas, hyd roller cam and cast iron exhaust manifolds.
Everything ran great on the dyno but there is some room for improvement. The AF ratio goes off at the start of the run so I need to work on the enrichment table.
Re: Super Sniper install [Re: AndyF] #2540127
08/22/18 06:51 PM
08/22/18 06:51 PM
AndyF Offline OP
AndyF  Offline OP
Video of one of the chassis dyno pulls: https://youtu.be/xG3-_YJGdZ8
