408 w2 heads 1/8mile racingarracuda #2533688
08/09/18 12:19 PM
08/09/18 12:19 PM
norway
56789 Offline OP
56789  Offline OP
norway
hi, just bought a 68 barracuda with 408W2 heads,W2 headers, 10,1 in comp,98pump gas, holley 830carb, mopar 557cam, bought a dynamic 9,5 street an strip converter, 4:89 rear and 727 street fighter. im gettin the engine in dyno in few weeks, does anywone has this engine?how mutch power? im going to use it to street and strip,28" tires most strip 1/8mile and want it to run 6,70. is this setup good enough?
Re: 408 w2 heads 1/8mile racingarracuda [Re: 56789] #2533700
08/09/18 12:39 PM
08/09/18 12:39 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My 408 with some mildly ported W2 heads I ported at 2850 pounds in my Duster ran 9.80’s (6.30) running 93 pump gas, 750 carb, 520 lift solid cam, 10.6 Comp, 4.88 gears, powerglide transmission, 1 7/8 headers and a 5200 stall convertor.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 408 w2 heads 1/8mile racingarracuda [Re: pittsburghracer] #2533719
08/09/18 01:02 PM
08/09/18 01:02 PM
norway
56789 Offline OP
56789  Offline OP
norway
thanks, could be a good 1/8mile on my car, how mutch horsepower can i hope for in the dyno?
Re: 408 w2 heads 1/8mile racingarracuda [Re: 56789] #2533739
08/09/18 01:27 PM
08/09/18 01:27 PM
PA.
"Little"John
"Little"John
PA.
44 years of building my own engines and I never dyno’d one. The only number I care about is ET.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 408 w2 heads 1/8mile racingarracuda [Re: pittsburghracer] #2533773
08/09/18 02:29 PM
08/09/18 02:29 PM
dogdays Offline
dogdays  Offline
I'm using my Guess-Top Dyno to say somewhere between 560 and 610 hp at the flywheel. Sounds like you need a 'Glide.
R.
Re: 408 w2 heads 1/8mile racingarracuda [Re: dogdays] #2534048
08/10/18 03:00 AM
08/10/18 03:00 AM
norway
56789 Offline OP
56789  Offline OP
norway
yes maybe need a glide, with only 2-4 races a year ihave to make sure all is good, also in the dyno.thre is no msd ignition, would it be better with crank trigger?
Re: 408 w2 heads 1/8mile racingarracuda [Re: 56789] #2534054
08/10/18 03:35 AM
08/10/18 03:35 AM
Cab_Burge Online work
Cab_Burge  Online Work
I built a similar(less compression) 340 with a 4.0 inch stroke crankshaft with a set of race W2 mildly ported heads and Mopar W2 intake with a custom ground solid lifter Comp Cams, that motor made 525 HP on CA pump swill back in 1994 or so shruggy
The owner put it in a 1969 Cuda fast back that ran a best of 11.0 in the 1/4 mile on the motor and 9.90s with NOS hammer
IHTHs
