Crager Wheel lug nuts loosening #2532239
08/06/18 12:35 PM
08/06/18 12:35 PM
P
Paul_Fancsali Offline OP
P
New crager 15x7 small bolt wheels keep will mysteriously loosen u for no reason Almost lost a wheel again rear drums7/16 x20 studs I may go with long studs and cut the cap end off the lug nuts {Crager}no one makes open ended lug nuts for the 7/16 studs Any suggestions? Want to avoid locktite
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2532249
08/06/18 12:53 PM
08/06/18 12:53 PM
Alberta
rustbuckett68 Offline
Alberta
Shanks too long and bottoming out? Do they fit the hole opening snugly?
Re: Crager Wheel lug nuts loosening [Re: rustbuckett68] #2532330
08/06/18 04:14 PM
08/06/18 04:14 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Shank style lug nuts have been good for me as far a staying tight. New Cragars are unilug so that may or may not be an issue??
I would verify the studs aren't too long as mentioned. Also if the shank part protrudes deeper than the thickness of the wheel that will hose you as well.
Re: Crager Wheel lug nuts loosening [Re: Neil] #2532333
08/06/18 04:19 PM
08/06/18 04:19 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Small bolt lugs nuts are unique, never had an issue with old stock, maybe the new one's aren't quite right. shruggy Nobody makes an open end lug nut for those, up until a few years ago when the started repopping them the lug nuts were unobtainium.
JB Rhinehart, Realist
A-Body's RULE!
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2532355
08/06/18 04:56 PM
08/06/18 04:56 PM
P
P
The 1st time the studs just broke off This time I lost 2 of the lug nuts and the other 3 were loose> the lugs are deep enough to handle the depth of wheel however the replacement studs don't have the knurl length of original studs
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2532435
08/06/18 07:11 PM
08/06/18 07:11 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Same wheel/rim each time? Same axle each time? Any pics?
Re: Crager Wheel lug nuts loosening [Re: mopars4ever] #2532483
08/06/18 08:40 PM
08/06/18 08:40 PM
IN
ahy Offline
ahy  Offline
IN
How hard would it be to replace with 1/2" studs? I am pretty sure the wheels could handle the larger diameter.
Re: Crager Wheel lug nuts loosening [Re: ahy] #2532582
08/06/18 11:55 PM
08/06/18 11:55 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No way to use 1/2" studs with these wheels, you have to have had a set to know what fits these wheels. Like I said earlier, special lug nuts are used and only fit small bolt Cragars. The register of the 4" bolt pattern and the smaller center hole negates drilling the hole any larger.
A-Body's RULE!
Re: Crager Wheel lug nuts loosening [Re: Rhinodart] #2532753
08/07/18 12:25 PM
08/07/18 12:25 PM
moparx Offline
moparx  Offline
as an experiment, try some teflon pipe thread tape on one nut/stud, then keep a close eye on it to see if it loosens up. just thinking out of the box here ....... shruggy those small pattern cragars are one of a kind as rhino said. you also need a thin [small diameter] deepwell socket to fit the nuts that won't scratch up the wheel center area.
beer
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2532755
08/07/18 12:31 PM
08/07/18 12:31 PM
Indiana
thrillbilly1974 Offline
Indiana
If these are unilug Cragars, you must use the correct offset washer and shank lug nuts.
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2532766
08/07/18 01:06 PM
08/07/18 01:06 PM
P
P
I have a stock of older lugnuts I will give those a shot. Thanks to all who have replied!
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2532772
08/07/18 01:15 PM
08/07/18 01:15 PM
WA
tman Offline
tman  Offline
WA
Info from Cragar
https://www.cragarwheel.com/news/aftermarket-wheel-installation-guidelines
No mention of Unilug in this article, but if you have them, get the correct lug nuts and washers.
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2532799
08/07/18 02:16 PM
08/07/18 02:16 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had one left rear loosen up one time. My fault, I did not recheck the torque after re-installing them soon enough. I lost 2 of the lug nuts & the other three were loose. The wheel started making a squeeling noise before a wobble occurred which made me pull over. I tightened the three and removed one off of two wheels from the other until I got home.
Before driving again I removed and replaced all 5 studs just to be safe along with a couple new lugs & now keep a couple of extra lug nuts with me in the glove box.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2532802
08/07/18 02:26 PM
08/07/18 02:26 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
someone is loosening them... sbp are NON UNI-LUG..never had one come loose on mine ran em for years.. check them regularly and put up a game camera to watch your car..
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2533575
08/09/18 01:25 AM
08/09/18 01:25 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I just read this and decided to checkout my Dart. 19 of 20 were not torqued to 85. The fronts were all loose. One of the fronts was missing! Wheel Vintiques Rally's with the chrome, enclosed shoulder lug nuts. Glad I checked!
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2533903
08/09/18 07:03 PM
08/09/18 07:03 PM
BlueRacer69 Offline
BlueRacer69  Offline
What is the torque spec's for Cragar Mags and the 7/16 lug nuts? I just got a set of new Cragar S/S and lug nuts, for my Dart but have not had a chance to test fit them yet. Thanks.
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2533910
08/09/18 07:25 PM
08/09/18 07:25 PM
northwest USA
N
NANKET Online work
NANKET  Online Work
N
northwest USA
Torque specs are from the 1970 service manual.
55 ft lbs for A body
65 ft lbs for B & C body
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2533929
08/09/18 08:23 PM
08/09/18 08:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Those torque specs are for factory steel wheels not aftermarket chrome mags. The specs I use on my wheels is tighten the crap out of them without warping the rotors. If you have drum brakes then don't sweat warping them. grin
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2533932
08/09/18 08:44 PM
08/09/18 08:44 PM
northwest USA
N
NANKET Online work
NANKET  Online Work
N
northwest USA
The torque specs are for the stud not the wheel or the nut.
If someone advises you to "tighten the crap out of" your lug nuts, think that over before following that advice.
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2533993
08/09/18 11:45 PM
08/09/18 11:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It's worked for me for 50 years and never had a lug come loose or stud break. In case you haven't noticed most cars call for 85-100ftlbs now days. shruggy
