I think I know what I want to build this winter #2533528
08/08/18 11:26 PM
08/08/18 11:26 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Except with more compression...All I need is a 6.4 block.
https://www.modernmusclextreme.com/p-255...erformance.aspx
Re: I think I know what I want to build this winter [Re: Dragula] #2533555
08/09/18 12:27 AM
08/09/18 12:27 AM
USA
hudsonhornet7x Offline
USA
Well I happen to own a new 6.4 block. Looking to buy or swap? PM me if you want more info.
Re: I think I know what I want to build this winter [Re: Dragula] #2533583
08/09/18 01:52 AM
08/09/18 01:52 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Looks like it would be pretty stout but you end up with a compression height of 1" and a rod ratio of 1.44, things get pretty tight with a big stroke in a gen III
Re: I think I know what I want to build this winter [Re: WO23Coronet] #2533608
08/09/18 07:41 AM
08/09/18 07:41 AM
Dragula Offline OP
Dragula  Offline OP
You can't beat displacement. And a 4.25 crank over the 4.080 in the other builds will feel like a whole nuther world. I want one at 12.5:1 compression.
My 512 combo seems to have maxed out at 6.19 so far in the 1/8th...I think this would put the car in the 5's...
Re: I think I know what I want to build this winter [Re: Dragula] #2533634
08/09/18 09:52 AM
08/09/18 09:52 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
With the Nickle content in the BGE the side loading of a 1.44 rod ratio doesn't affect the block like it does some other makes, granted you still have the drag aspect.
Those 454's can be a monster and with the Edlebrock heads I think you can crack in to the high5's
But I'd wait till after Dec
Re: I think I know what I want to build this winter [Re: ric3xrt] #2533698
08/09/18 12:38 PM
08/09/18 12:38 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
But I'd wait till after Dec [/quote]
Ok. Spill it! What new is coming?
Re: I think I know what I want to build this winter [Re: fbs63] #2533710
08/09/18 12:51 PM
08/09/18 12:51 PM
USA
USA
Ok. Spill it! What new is coming? [/quote]
I would assume the new 426 block.
Re: I think I know what I want to build this winter [Re: ric3xrt] #2533902
08/09/18 07:02 PM
08/09/18 07:02 PM
Dragula Offline OP
Dragula  Offline OP
The E-heads I have flow north of 370 at .650...With 450 cubes, I would think this thing would fly. I have to get them CC'd to figure out compression ratio. Working on a quote thru Hughes at the moment.
For cam, I am thinking right around 265 or so duration, not sure yet, but the more cubes the better. My car is not setup for high rpm, more of a lower rpm bracket type car. Curious where you bracket guys shift these things. I shift the 512 at only 6300-6400 and it typically goes 6.20 at 111mph with a 1.35 60ft.
So what happens in Dec? I would love to see one of these approach 500 cubes, that would be outrageous, and right up my alley. I am looking to do somthing different this year....
