8.75 rear yoke straps #2533485
08/08/18 09:23 PM
08/08/18 09:23 PM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
Is there any size difference in the straps that bolt the U-joint to the rear end yoke. 7260 vs 7290 U-joints. How do you tell any difference?
Re: 8.75 rear yoke straps [Re: NANKET] #2533489
08/08/18 09:30 PM
08/08/18 09:30 PM
IN
ahy Offline
ahy  Offline
IN
Cap diameter is different (1.078" vs 1.125"). See attached. I think the fit difference would be noticeable.
http://www2.dana.com/Expert/wc.dll?hvtss~dedsec~2~13~04~
Re: 8.75 rear yoke straps [Re: ahy] #2533496
08/08/18 09:51 PM
08/08/18 09:51 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Yes: They are different.
Sheldon
Re: 8.75 rear yoke straps [Re: NANKET] #2533512
08/08/18 10:37 PM
08/08/18 10:37 PM
yes, there different enough to not work properly when using the 7260 on the 7290 yokes tsk
If you go the other way it will fail also shruggy
The straps are suppose to stop front to rear movement, not side to side. The U joint caps should snap into place and not move at all without the caps scope
If they move side to side it is time for a new yoke up wrench
