gearvendors - difference between P type & J type ? #2532764
08/07/18 12:59 PM
08/07/18 12:59 PM
moparx Online content OP
moparx  Online Content OP
what are the differences between the P type and J type gearvendor overdrive units ? are they just in the output shaft and housings, or are there internal differences as well ? is the main unit used in volvo applications a lighter duty unit, or are these sections the same as used in the "normal" gearvendor kits ? i realize there are different mount holes and speedometer cable locations. i am looking for a unit i can make a custom adapter from 9" or so T-601 bar stock. also, what diameter and spline count is the "normal" input shaft ? thank you for your input on this topic.
beer
Re: gearvendors - difference between P type & J type ? [Re: moparx] #2533176
08/08/18 09:55 AM
08/08/18 09:55 AM
bump.......... bump
beer
Re: gearvendors - difference between P type & J type ? [Re: moparx] #2533207
08/08/18 11:27 AM
08/08/18 11:27 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would just call Gear Vendors, they are a friendly bunch in my experience.
Re: gearvendors - difference between P type & J type ? [Re: 340Cuda] #2533817
08/09/18 04:00 PM
08/09/18 04:00 PM
dogdays Offline
dogdays  Offline
https://en.wikipedia.org/wiki/Overdrive_(mechanics)#In_Europe
The basic design is the same, although the modern GearVendors units certainly have a higher torque rating than those found behind Volvo Fours.
The J type came first, the P type was the last design.
GearVendors bought the overdrive, lock stock and barrel. They are the sole manufacturers for a while now. They have uprated its torque handling capabilities.
It's a planetary gear arrangement which is hydraulically activated, like an automatic transmission.
I wouldn't advocate trying to adapt a Volvo unit to your hot rod.
R.
