Re: Crager Wheel lug nuts loosening
[Re: rustbuckett68]
#2532330
08/06/18 04:14 PM
08/06/18 04:14 PM
Posts: 20,598 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Shank style lug nuts have been good for me as far a staying tight. New Cragars are unilug so that may or may not be an issue??
I would verify the studs aren't too long as mentioned. Also if the shank part protrudes deeper than the thickness of the wheel that will hose you as well.
[Re: Neil]
#2532333
08/06/18 04:19 PM
08/06/18 04:19 PM
Posts: 43,558 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Small bolt lugs nuts are unique, never had an issue with old stock, maybe the new one's aren't quite right. Nobody makes an open end lug nut for those, up until a few years ago when the started repopping them the lug nuts were unobtainium.
JB Rhinehart, Realist
A-Body's RULE!
[Re: ahy]
#2532582
08/06/18 11:55 PM
08/06/18 11:55 PM
Rhinodart
Rhinotruck
Rhinotruck
No way to use 1/2" studs with these wheels, you have to have had a set to know what fits these wheels. Like I said earlier, special lug nuts are used and only fit small bolt Cragars. The register of the 4" bolt pattern and the smaller center hole negates drilling the hole any larger.
A-Body's RULE!
[Re: Paul_Fancsali]
#2532799
08/07/18 02:16 PM
08/07/18 02:16 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I had one left rear loosen up one time. My fault, I did not recheck the torque after re-installing them soon enough. I lost 2 of the lug nuts & the other three were loose. The wheel started making a squeeling noise before a wobble occurred which made me pull over. I tightened the three and removed one off of two wheels from the other until I got home.
Before driving again I removed and replaced all 5 studs just to be safe along with a couple new lugs & now keep a couple of extra lug nuts with me in the glove box.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Paul_Fancsali]
#2533910
08/09/18 07:25 PM
08/09/18 07:25 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
Torque specs are from the 1970 service manual.
55 ft lbs for A body 65 ft lbs for B & C body
