Need a good starter #2531895
08/05/18 02:40 PM
08/05/18 02:40 PM
Norway
General 68 Offline OP
Norway
My RobbMc starter shredded the teeth inside the outer ring gear and had me stranded 250 miles away from home. Looks like plastic gear! 11 years old, not ran hard/much. Thinking of buying a standard mini starter this time, but not sure if it will fit or what brand and where to get. Quality over price!
440-10:1cr, TKO 600, 143 teeth flywheel, Lakewood schattershield, TTI 2" headers.
What starter(s) will fit and last?
Re: Need a good starter [Re: General 68] #2531922
08/05/18 03:51 PM
08/05/18 03:51 PM
IL
furious70 Offline
furious70  Offline
IL
I just buy JY mini's from 5.9 mag trucks. Some I've had to grind on the housing a little, and you have to remove the extra wiring adapter thing. Have also bought replacement starter from rock auto for those trucks
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Need a good starter [Re: General 68] #2532118
08/06/18 12:27 AM
08/06/18 12:27 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just get oine for a 360 Dodge like 99 or so.That or 440 source has them cheap.Some are more powerful than others.Thats wht I use 360 Ram starters.My reman from Advancehas been in for almost 20 years.Still perfect and the 12.5 440 cranks like a /6.Rocky
Chrysler Firepower
Re: Need a good starter [Re: therocks] #2532160
08/06/18 07:39 AM
08/06/18 07:39 AM
Norway
Norway
So far -good, but TTI states that their 2" headers on a 440 with 143 teeth flywheel need the RobbMc starter. Is that correct? Not sure if I want to drop another ยง300,- at a starter with plastic ring gear...
Re: Need a good starter [Re: General 68] #2532194
08/06/18 11:13 AM
08/06/18 11:13 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a scatter shield 143 teeth 2 inch old TTIs on my 440.The mini is tight but fits.Been on for 20 years and no problems.Rocky
Chrysler Firepower
Re: Need a good starter [Re: therocks] #2532200
08/06/18 11:31 AM
08/06/18 11:31 AM
Norway
Norway
Thanks Rocks! How old are your TTI's? Mine were purchased spring 2007. Hopefully they are the same as yours.
Re: Need a good starter [Re: General 68] #2532257
08/06/18 01:13 PM
08/06/18 01:13 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would check with RobbMc good chance that part has been upgraded.
Bill
Re: Need a good starter [Re: General 68] #2532265
08/06/18 01:26 PM
08/06/18 01:26 PM
Ohio
lockjaw-express Offline
Ohio
I have the RobbMC Starter on my 440, however my next starter will be the new Meziere Starter that also has indexing...the plastic gear still spooks me.
Re: Need a good starter [Re: General 68] #2532267
08/06/18 01:35 PM
08/06/18 01:35 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mine are actually CPPAs Bought them at least 22 years ago.They were some of the forst made.TTI took over and thats the mane change.Ill have to replace them some day.LOL.Rocky
Chrysler Firepower
