INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? #2531609
08/04/18 08:27 PM
08/04/18 08:27 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
I have had an INDY blue 1.6 ratio rocker break on the #8 cylinder intake side. This was on a SR head 493 stroker engine. I also know of a 440 with SR heads that broke on the same position # 8 cylinder intake side.
I have attached pictures of both failures. So I'm wondering if others out there have had the same rocker break? If so is there a weak point back there on # 8?
Thanks! MJ
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2531610
08/04/18 08:29 PM
08/04/18 08:29 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It was just their time.
Probably wise to replace them all........ especially if you’re running a roller cam with decent spring pressure.
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: fast68plymouth] #2531619
08/04/18 08:48 PM
08/04/18 08:48 PM
fullmetaljacket Offline
I've never trusted those aluminum rockers. I've always opted for the steel Magnum roller tipped rockers with assurance.
I believe after so many cycles of hot to cold to hot again along with all the pressures at that point, the aluminum will give.
Sorry for your issues.
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2531640
08/04/18 09:42 PM
08/04/18 09:42 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I had two sets of Comp steel rockers weld themselves to the shafts. .660 roller with just over 700lbs. over the nose. T&D or Jesel IMO.
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2531678
08/04/18 11:02 PM
08/04/18 11:02 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Push rod bent ? Valve touched piston ?
I have broken 2 Crane gold rockers but they are a little weaker to start with, at the time of failure the engines where being beat on.
Go buy a set of Hughes rockers that don't have needle roller bearings
1963 Plymouth Max Wedge
1971 Barracuda
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2531679
08/04/18 11:05 PM
08/04/18 11:05 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Oh yeah, I think the last one we broke was #8
1971 Barracuda
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2531680
08/04/18 11:05 PM
08/04/18 11:05 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
It's a indy rocker they break
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: a493demon] #2531702
08/04/18 11:43 PM
08/04/18 11:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have a set Of Indy rockers on my 360-1 heads but only have a small .650 lift solid cam in this engine. I bought a set of used T&D rockers from a moparts member that will be going on over the Winter when I step up to a roller cam
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2531796
08/05/18 09:18 AM
08/05/18 09:18 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
never used indy rockers black or blue,use hardland sharps and smith bros push rods
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2531802
08/05/18 09:45 AM
08/05/18 09:45 AM
crabman173
crabman173
Those Indy rockers --made by Dove have always been sold by Indy as the rocker--Indy KNOWS that they can't handle roller spring pressures or high spring pressures for long---You have experienced the same failure that hundreds of Indy customers have seen over the years--they run for a while but then--K Boom You use them on a street solid cam and they may last forever--use them in a serious race unit and well.....
Hughes, Harlands, Jesels, etc for real race engines
BTW I have never seen an Indy small block rocker do that but I have seen dozens of the BB units fail--replace the entire set now or risk future destruction
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: Dave Hall] #2531805
08/05/18 09:55 AM
08/05/18 09:55 AM
So. Burlington, Vt.
So. Burlington, Vt.
Before they started putting bushings in them, the Comp steel rockers were “rated” for 350lbs open load.
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: ] #2531806
08/05/18 10:00 AM
08/05/18 10:00 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
this! I've seen them break also. they're not a serious hot rod rocker.
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2531821
08/05/18 11:16 AM
08/05/18 11:16 AM
UK
rb446 Offline
rb446  Offline
UK
Some guys here running those rockers also had 1 showing signs of cracking, and they weren't running hefty spring pressures with their mild roller, happen to be on SR's as well, don't know which cyl it was on but it seems they are a mild perf application rocker only, they went HS rockers.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: rb446] #2531858
08/05/18 01:28 PM
08/05/18 01:28 PM
N.W. INDIANA
N.W. INDIANA
Thanks for all the replies!
I just thought there might be something up with that # 8 cylinder?
I replaced the rockers in the 493 stroker with Harland Sharps right after that. I had the same thought that there might be 15 more ready to go? The rockers in the other engine have been replaced as well.
MJ
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2531881
08/05/18 02:05 PM
08/05/18 02:05 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Maybe check valve to piston clearance on # 8 just to be sure.
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2531891
08/05/18 02:30 PM
08/05/18 02:30 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Check top of valve guide to bottom of valve spring retainer clearance,especially if showing up on the same rocker. I missed that one many years ago. It baffled me for a while and cost me some money!
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: ] #2532020
08/05/18 08:13 PM
08/05/18 08:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Here's your answer right here.
Doug
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: dvw] #2532065
08/05/18 09:47 PM
08/05/18 09:47 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Well you will not be replacing them with the Indy rockers. They have ceased production on them to include the small blocks. Now you have to step up to the HS, TD or Jesel. They worked fine on Hyd.or solid cams, just not rollers.
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2532070
08/05/18 10:08 PM
08/05/18 10:08 PM
crabman173
crabman173
Google Dove Rocker Arms and wowzer it pops right up--they are known Ford makers but also sold Indy all they wanted until they did not want them anymore--They still have them Call and let us know
how it goes
Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE? [Re: moparjohn] #2532240
08/06/18 12:35 PM
08/06/18 12:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
I use the Mancini rockers made by HS when I’m looking for an “entry level” type rocker........ something along the lines of the Crane golds.
Of the stuff I’ve used recently, those are the least expensive rockers that I’ll trust, but I wouldn’t use them with a solid roller running high spring loads.
