felpro 1008 any tricks to help sealing?
#2531771
08/05/18 02:03 AM
08/05/18 02:03 AM
RapidRobert
360 iron block/iron heads/short duration (30 minutes) racing/stock bolts. Would you guys recommend any thing such as spraying it with Permatex "high tack". retorquing after first fireup after it cools. breaking loose each head bolt 3/4 turn then back to full torque. or anything else. Heads/decks are flat. My OCD wants more. thank you for your time.
Re: felpro 1008 any tricks to help sealing?
[Re: RapidRobert]
#2531822
08/05/18 11:17 AM
08/05/18 11:17 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I ran them on my 11:1 360 with aluminum heads. I never had any issues, I used them with bolts and with studs over the years. The one time I did go through the trouble to retorque after a heat cycle not a single one moved so I never did it again.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2531883
08/05/18 02:09 PM
08/05/18 02:09 PM
RapidRobert
Alright, it sounds if I stick to std procedures/no shortcuts & if I see an issue (bad threads etc) then resolve it that I will be fine. thank you.
[Re: RapidRobert]
#2531942
08/05/18 04:45 PM
08/05/18 04:45 PM
crabman173
crabman173
I ran them on a 12:1 360 for years with bolts and studs--I ran clear tube on EVAC I would start to see a "mist" or condensation in one side after a while--That was the sign to replace the gasket Before it caused trouble Usually could get 150 runs before trouble--Studs did seem to help some --when checked the outside row ( short ones) would always be a tad loose--started giving them an extra yank when torquing down and that went away I have always used a spray Hylomar on Cometics but never on the 1008's small blocks--ten bolts = gasket trouble sooner or later in a small block Mopar
[Re: ]
#2531956
08/05/18 05:19 PM
08/05/18 05:19 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m not a lover of bolts on race engines since you are relying on NC threads. I like the smoothness of NF threads and their clamping abilities.
[Re: Bad340fish]
#2531981
08/05/18 06:34 PM
08/05/18 06:34 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The one time I did go through the trouble to retorque after a heat cycle not a single one moved so I never did it again. Do you mean you applied the original torque to the stationary bolt and it didn't move? If so, that doesn't mean it was at the correct torque. Like Robert said, first loosen the bolt and then re-torque; correct torque value can only be achieved on a moving fastener.
[Re: ]
#2532069
08/05/18 10:05 PM
08/05/18 10:05 PM
RapidRobert
I have always used a spray Hylomar on Cometics but never on the 1008's small blocks--ten bolts = gasket trouble sooner or later in a small block Mopar I do have a new can of spray Hylomar sitting on the front room table. & that reminds me I coulda swore someone said to use it on head bolts ???
[Re: RapidRobert]
#2532185
08/06/18 10:54 AM
08/06/18 10:54 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Do not use sealer on the gaskets. Use the standard advised installation procedures. No issue. Morerr important that both surfaces are flat. Some used to like the finish of a Blockmaster 85 machine, due to the fact it gave the gasket some " grip". Not sure on that one, but as stated, they will work fine.
RIP Monte Smith
[Re: RapidRobert]
#2532269
08/06/18 01:38 PM
08/06/18 01:38 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Installed lots of them and the BB one.Plus we used FelPros at work for all heads.Never used a thing.Just nice and clean and never a problem.Have them on my sons 360 with 10.8 comp.Rocky
Chrysler Firepower
[Re: justinp61]
#2532392
08/06/18 05:54 PM
08/06/18 05:54 PM
RapidRobert
Alright, sounds good no sealer & std procedures. thanks guys
[Re: RapidRobert]
#2536801
08/15/18 04:26 PM
08/15/18 04:26 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Robert -- I'm a former FP engineer (and I wrote the installation tips for all the aftermarket gasket sets)... rule of thumb:
Fiber face = no chemical needed Metal face = apply thin even coat of tacky sealer (not RTV!)
The 1008 gasket is fiber faced and already has an anti-stick coating that give a little additional sealing assurance (but the primary purpose is anti-stick for easy/clean gasket release if/when needed).
Just be certain of flatness, smoothness and proper torque specs.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2537671
08/17/18 02:57 PM
08/17/18 02:57 PM
RapidRobert
Mitch you're the man! all noted. (just my OCD telling me that there has to be "something" else that I can do that will "improve" things!)
