hunting for vacuum leaks
#2531634
08/04/18 09:28 PM
08/04/18 09:28 PM
dartman366
Mt. Vernon, Ohio
what mean's do you guys that run a vac pump use to check for leaks, also what oil breather are you using, I have a small moroso that has a breather on top and a petcock on bottom to drain but has some sort of coarse steel wool/scratchy pad like baffeling and is doing a poor job of containing the oil, I have to keep a couple of shop towel's wrapped and zip tied around the breather cap.
Re: hunting for vacuum leaks
[Re: Dave Hall]
#2532042
08/05/18 09:06 PM
08/05/18 09:06 PM
dartman366
Mt. Vernon, Ohio
The shop towel, zip tie is a typical deal. Same on mine. I think that the volume of the tank is so much smaller than the volume of the engine that it moves a lot of air through it. You could try smoke at or around 3,000 rpm. Maybe bench test the smoke at the largest vacuum the engine makes so you can get a feel for what it trails like. It will be hard to detect. The valley pan and valve cover area are the most likely culprits. Running a gear or belt drive will help that area. The oil pan is the largest gasket area but gets some help from the oil itself. I know that pulling the dip stick and capping the tube made an inprovement and cut back the amount of oil in the tank but this is with little to no vac showing on the gage and the regulator wide open to the point the check ball isn't even seated, so I know it's sucking air somewhere, just got to find it.
[Re: dartman366]
#2532046
08/05/18 09:12 PM
08/05/18 09:12 PM
Posts: 1,557 Michigan
Kiddart
Check the flatness of your valve covers. a friend of mine had the same issue
Thank you Kiddart
[Re: dartman366]
#2532050
08/05/18 09:16 PM
08/05/18 09:16 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I like to pressurize the engine with a constant 12 to 15 psi. You might have to get creative to install a fitting.. then I spray around with a spray bottle with water and 10% dish soap. You will be surprised at what leeks you will find
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Kiddart]
#2532051
08/05/18 09:18 PM
08/05/18 09:18 PM
dartman366
Mt. Vernon, Ohio
rails on the vc's are machined and so are the rails on the trick flow head's, using the Superformance CarbonX gaskets.
[Re: WHITEDART]
#2532055
08/05/18 09:25 PM
08/05/18 09:25 PM
dartman366
Mt. Vernon, Ohio
I like to pressurize the engine with a constant 12 to 15 psi. You might have to get creative to install a fitting.. then I spray around with a spray bottle with water and 10% dish soap. You will be surprised at what leeks you will find Thanks for the tip Shilo, that the kind of thing I was wanting to know.
[Re: dartman366]
#2532176
08/06/18 10:19 AM
08/06/18 10:19 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Before buying a big electric vacuum pump, I had a 1hp electric motor and a long v-belt. I would jack up the car and set the pump below it with the long v belt and run the pump then light up a cigar and watch the smoke disappear into the engine.
joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2532548
08/06/18 10:47 PM
08/06/18 10:47 PM
dartman366
Mt. Vernon, Ohio
joe Well, thats another way to skin a cat, as they say, what ever work's
[Re: dartman366]
#2532831
08/07/18 03:42 PM
08/07/18 03:42 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
I use either Shilo method at the track or a smoke making at the shop. Been using smoke machines for years on new car repairs of EVAP system. An invaluable tool for sure.
[Re: Al_Alguire]
#2533141
08/08/18 02:22 AM
08/08/18 02:22 AM
RapidRobert
this fitting works good for pressurizing a system with shop air & it is less than $3 at O'reillys. Be carefull, if there ain't much air (full of coolant) it will pump up FAST & 5 psi is plenty. I used it in the cooling temp sender 1/8 NPT port & on a seperate issue I made a smoke pump from a burning rag with baby oil in a paint can on a utube vid! (I found the leak).
