Re: INDY SR BLUE 1.6 ROCKER FAILURES # 8 CYL INTAKE?
[Re: moparjohn]
#2531610
08/04/18 08:29 PM
08/04/18 08:29 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It was just their time.
Probably wise to replace them all........ especially if you’re running a roller cam with decent spring pressure.
[Re: moparjohn]
#2531678
08/04/18 11:02 PM
08/04/18 11:02 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Push rod bent ? Valve touched piston ?
I have broken 2 Crane gold rockers but they are a little weaker to start with, at the time of failure the engines where being beat on.
Go buy a set of Hughes rockers that don't have needle roller bearings
1963 Plymouth Max Wedge 1971 Barracuda
[Re: moparjohn]
#2531679
08/04/18 11:05 PM
08/04/18 11:05 PM
ozymaxwedge
Australia
Oh yeah, I think the last one we broke was #8
[Re: a493demon]
#2531702
08/04/18 11:43 PM
08/04/18 11:43 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a set Of Indy rockers on my 360-1 heads but only have a small .650 lift solid cam in this engine. I bought a set of used T&D rockers from a moparts member that will be going on over the Winter when I step up to a roller cam Untitled by John Cadamore, on Flickr
[Re: moparjohn]
#2531802
08/05/18 09:45 AM
08/05/18 09:45 AM
crabman173
crabman173
Those Indy rockers --made by Dove have always been sold by Indy as the rocker--Indy KNOWS that they can't handle roller spring pressures or high spring pressures for long---You have experienced the same failure that hundreds of Indy customers have seen over the years--they run for a while but then--K Boom You use them on a street solid cam and they may last forever--use them in a serious race unit and well..... Hughes, Harlands, Jesels, etc for real race engines BTW I have never seen an Indy small block rocker do that but I have seen dozens of the BB units fail--replace the entire set now or risk future destruction
[Re: Dave Hall]
#2531805
08/05/18 09:55 AM
08/05/18 09:55 AM
fast68plymouth
So. Burlington, Vt.
I had two sets of Comp steel rockers weld themselves to the shafts. .660 roller with just over 700lbs. over the nose. T&D or Jesel IMO. Before they started putting bushings in them, the Comp steel rockers were “rated” for 350lbs open load.
[Re: ]
#2531806
08/05/18 10:00 AM
08/05/18 10:00 AM
Posts: 3,916 usa
lewtot184
usa
Those Indy rockers --made by Dove have always been sold by Indy as the rocker--Indy KNOWS that they can't handle roller spring pressures or high spring pressures for long---You have experienced the same failure that hundreds of Indy customers have seen over the years--they run for a while but then--K Boom You use them on a street solid cam and they may last forever--use them in a serious race unit and well..... Hughes, Harlands, Jesels, etc for real race engines BTW I have never seen an Indy small block rocker do that but I have seen dozens of the BB units fail--replace the entire set now or risk future destruction this! I've seen them break also. they're not a serious hot rod rocker.
[Re: moparjohn]
#2531821
08/05/18 11:16 AM
08/05/18 11:16 AM
Posts: 570 UK
rb446
UK
Some guys here running those rockers also had 1 showing signs of cracking, and they weren't running hefty spring pressures with their mild roller, happen to be on SR's as well, don't know which cyl it was on but it seems they are a mild perf application rocker only, they went HS rockers.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: ]
#2532020
08/05/18 08:13 PM
08/05/18 08:13 PM
Posts: 9,835 MI, usa
dvw
MI, usa
Those Indy rockers --made by Dove have always been sold by Indy as the rocker--Indy KNOWS that they can't handle roller spring pressures or high spring pressures for long---You have experienced the same failure that hundreds of Indy customers have seen over the years--they run for a while but then--K Boom You use them on a street solid cam and they may last forever--use them in a serious race unit and well..... Hughes, Harlands, Jesels, etc for real race engines BTW I have never seen an Indy small block rocker do that but I have seen dozens of the BB units fail--replace the entire set now or risk future destruction Here's your answer right here. Doug
[Re: moparjohn]
#2532070
08/05/18 10:08 PM
08/05/18 10:08 PM
crabman173
crabman173
Google Dove Rocker Arms and wowzer it pops right up--they are known Ford makers but also sold Indy all they wanted until they did not want them anymore--They still have them Call and let us know how it goes
[Re: moparjohn]
#2532240
08/06/18 12:35 PM
08/06/18 12:35 PM
fast68plymouth
So. Burlington, Vt.
I use the Mancini rockers made by HS when I’m looking for an “entry level” type rocker........ something along the lines of the Crane golds.
Of the stuff I’ve used recently, those are the least expensive rockers that I’ll trust, but I wouldn’t use them with a solid roller running high spring loads.
