I remember seeing some threads years ago about changing the steering column with shifter on a 1965 B body to a 1966 column so you can use the mechanical linkage instead of the 1 year only cable shift transmission...I've searched and looked for it but can't seem to find it.
What do you guys know that is involved? I remember it was almost a straight bolt-in?
1965 Plymouth Belvedere II hardtop
