1mm 1mm 2mm rings for a street driven motor
#2530803
08/03/18 01:48 AM
08/03/18 01:48 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Has anyone tried this? Bought a 408 rotating assembly and it came with a set of Mahle forged coated pistons and steel 1mm 1mm 2mm standard tension rings, piston to wall will be .003. I am only worried about oil control at highway speeds. Mahle claims it will be fine, new cars are getting them, yes but they have way better windage control than older stuff. Will be using a milodon 7qt pan, maybe a crank scraper would help.
Re: 1mm 1mm 2mm rings for a street driven motor
[Re: 4406bbl]
#2530807
08/03/18 02:01 AM
08/03/18 02:01 AM
Posts: 4,457 Washington
madscientist
Washington
It wil be fine. There is nor reason to run anything thicker than .062 anyway. You are at ~.040 so no biggie.
[Re: 4406bbl]
#2530852
08/03/18 10:22 AM
08/03/18 10:22 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
New cars also have very tight rod side clearances and run 5w20 oil.
I don’t think a 1/1/2 ring pack is a “slam dunk” in all situations.
[Re: 4406bbl]
#2530856
08/03/18 10:45 AM
08/03/18 10:45 AM
crabman173
crabman173
I agree Mahle is providing a ring package that may make a couple few more HP but is a nightmare to install for a back yard builder--You MUST use a tapered ring compressor to have a fighting chance of getting that oil ring in undamaged--block bores must have good chamfer as well Too much risk for almost no gain ( or very little gain)
Why they include these in street car kits makes no sense in real world just on paper
[Re: 4406bbl]
#2530883
08/03/18 11:37 AM
08/03/18 11:37 AM
Posts: 2,670 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Has anyone tried this? Bought a 408 rotating assembly and it came with a set of Mahle forged coated pistons and steel 1mm 1mm 2mm standard tension rings, piston to wall will be .003. I am only worried about oil control at highway speeds. Mahle claims it will be fine, new cars are getting them, yes but they have way better windage control than older stuff. Will be using a milodon 7qt pan, maybe a crank scraper would help. I would feel stupid if I paid money for new pistons and they had rings bigger than that. Welcome to the 21st century where you can buy showroom stock 800HP street cars that don't burn oil.
2011 Drag Pak Challenger
[Re: rickseeman]
#2530887
08/03/18 11:43 AM
08/03/18 11:43 AM
Posts: 20,193 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm to busy buying up and using all the old junk that the Gen 3 guys are selling for penny's on the dollar. I'll take those thick ring SLUGS. LOL
[Re: 4406bbl]
#2530905
08/03/18 12:16 PM
08/03/18 12:16 PM
crabman173
crabman173
It is not about oil--they will work perfect--it is not about HP they may make 5 more Big deal because that is a maybe it is about guys at home building an engine that requires a surgeons skill to get the damn oil ring in without squashing it
If modern was so damn good then why do you all want a 69 Charger?
[Re: 4406bbl]
#2530926
08/03/18 12:40 PM
08/03/18 12:40 PM
crabman173
crabman173
Well it keeps cars more original --they dripped. leaked etc when brand new We bought a new 66 Belvedere and every car in the showroom had large tin pan under the engine LOL At least it is not like a few years back when Mahle was sending out oil ring expanders that butted together HARD and were not right--when their tech was called they said that was right and anyone that did not agree was not a very good engine builder This was in the first Eagle big block kits that came with Mahle pistons Oh what fun to be the one that takes parts from 80 different makers many of whom have never actually seen a Mopar big block or small block and then.......make it all work
Saw an a for Golf Club salesman--Think I will apply
[Re: 4406bbl]
#2530963
08/03/18 01:46 PM
08/03/18 01:46 PM
crabman173
crabman173
I have had no issues with oil use on skinny rings I never said it was an issue I think I said no issue with that It is the other things that make that a poor decision for street stuff IMO almost No gain and serious potential for installation problems and...maybe..who knows after a few miles maybe not so smart to have such low tension oil rings in a danged ole hotrod mopar with 50 year old blocks Yea my new hemi truck has skinny rings for MPG--it sucks oil like crazy but that is apples to oranges
[Re: ]
#2530966
08/03/18 01:54 PM
08/03/18 01:54 PM
Posts: 20,193 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Most car engines aren’t designed to be two cycles. But what do I know. I don’t have a college degree to come up with some fancy formula or theory
[Re: fast68plymouth]
#2530975
08/03/18 02:27 PM
08/03/18 02:27 PM
madscientist
Washington
I don’t think a 1/1/2 ring pack is a “slam dunk” in all situations. Side clearance has nothing to do with oil control. Oil control on the cylinder walls is controlled by bearing clearance. If the OP is even running a 20w50 oil his bearing clearances shouldn't be much over .003 at the very most. In fact, hopefully he is setting his stuff to run on a 5w30 and buy a good oil.
[Re: 4406bbl]
#2531007
08/03/18 03:19 PM
08/03/18 03:19 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
They will be fine. Most of the OEM's are now using them. Mahle uses them for most of their application & they are an OEM supplier also. We build literally 1000's of race & street engine every year with a 1MM, 1MM, 2MM combo's with no issues.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 4406bbl]
#2531030
08/03/18 03:56 PM
08/03/18 03:56 PM
Posts: 11,639 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
They are doing ring packs thinner than that, even in some of the OEs. Just like any "exotic" part, you have to balance the cost and maintenance factor with the desired benefits and results. Vacuum pumps, dry sumps, block material, honing techniques, etc, etc. Replacing rings every 50 runs. Is it worth 5 or 10HP? Record setting Super Stock or Comp engine? Or a bracket, mid-level Stocker, Super Gas piece?
If a few horsepower are that important, you're likely spending thousands on the car as well - lightweight parts, ceramic bearings, etc.
[Re: dogdays]
#2531054
08/03/18 04:40 PM
08/03/18 04:40 PM
Thumperdart
State of confusion
Cmon, cmon, cmon!
Rod side clearances are not the meter in oil coming off the rod. The bearing-to-journal clearance is maybe 20% of that. It's like having two feet of 2" pipe connected to 1 foot of 4" pipe. Where is the restriction?
Reducing friction from rod side to crank makes horsepower, see piston-guided rods. I read recently about racers relieving some of the rod sides so there isn't as much friction between rod and crank.
Oh, well. I'll probably get slagged for this repetition of facts, but facts are facts and opinions are opinions.
R. Agree, and I run OLD Eagle Chevy 6.385 rods with .030+ rod side clearance and have for over 16 years...........
