CryO2 Cryogenic Intake Systems or cool can 2.0
#2530581
08/02/18 06:08 PM
08/02/18 06:08 PM
Posts: 7,143 my own world
theraif
my own world
Re: CryO2 Cryogenic Intake Systems or cool can 2.0
[Re: A/MP]
#2530741
08/02/18 11:37 PM
08/02/18 11:37 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Sad they had to screw up a simple power enhancer spiel by going with the cooler fuel being more powerful comment, unless maybe with diesel. Would also be best if air intake was completely divorced from the liquid co2 evaporation path.
[Re: theraif]
#2530754
08/02/18 11:58 PM
08/02/18 11:58 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
A friend of mine had this on the intercooler of his 04 Cobra ages ago. It actually made a fair amount more power on the chassis dyno(30HP maybe?) But it failed to ever produce results at the track. My thought was that on the dyno the CO2 really soaks into the heat exchanger and makes it cold but on the track the airflow pushes it through before it can have as much of an effect.
68 Barracuda Formula S 340
[Re: jcc]
#2530827
08/03/18 07:24 AM
08/03/18 07:24 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Sad they had to screw up a simple power enhancer spiel by going with the cooler fuel being more powerful comment, unless maybe with diesel. Would also be best if air intake was completely divorced from the liquid co2 evaporation path. Modern fuel with ethanol boils at a lower temperature than pure gas. If I run straight pump fuel in my car,it will literally boil the fuel out of the carb, and flood the engine. Wh3n I cut pump gas with some 110, this doesn’t happen.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2530860
08/03/18 10:55 AM
08/03/18 10:55 AM
jcc
Bitopia
Maybe in your case, but the "more power" claim by the video by creating a cooler fuel, is in your case only mainly to prevent "boiling", and is a crutch solution for a different purpose.
[Re: theraif]
#2530951
08/03/18 01:34 PM
08/03/18 01:34 PM
Posts: 4,208 New York
polyspheric
New York
If that's posible
Boffin Emeritus
[Re: theraif]
#2531055
08/03/18 04:43 PM
08/03/18 04:43 PM
polyspheric
New York
The tube insert sounds good, because the low pressure (gaseous) outlet can be ducted under the car or otherwise avoid to intake air path. They don't explain how to choose the tube size? If you have 3" plumbing now from the compressor and you get their 3" tube, how much of a restriction is the area of the bulb?
Boffin Emeritus
