Race engine oil capacity
#2526722
07/25/18 01:47 AM
07/25/18 01:47 AM
Posts: 84 La.USA
rick4106
La.USA
Son has a 496 lo deck with milodon dragster pan. Part # 31161 with dual line pump and remote wix spin on filter. Milodon shows 9 quarts plus filter. What oil capacity is everybody using?
Re: Race engine oil capacity
[Re: rick4106]
#2527684
07/27/18 12:34 AM
07/27/18 12:34 AM
RapidRobert
Milodon shows 9 quarts plus filter. What oil capacity is everybody using? 5-6 qts in the sump is plenty. with 9 he sure wont be hurtin capacity wise
[Re: rick4106]
#2527706
07/27/18 01:25 AM
07/27/18 01:25 AM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I use an empty quart bottle and water. Quart at a time in the pan on the bench to actually determine what should be in it. Just run it up to the tray or just below it. Running an accusump you can run it a bit low if you want.
[Re: rick4106]
#2527730
07/27/18 04:29 AM
07/27/18 04:29 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
I would start with what Mlidon recommends and then see if you want to test it with one less quart or not When you say remote mounted Wix oil filter which remote filter # does your use ?
[Re: rick4106]
#2527735
07/27/18 07:27 AM
07/27/18 07:27 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A lot depends on how much oil flows through the motor and can't get back to the pan quik enough, and also how hard you brake to slow down the car. I had to run 10 quarts in mine with race clearances in the bearings, and had to go to an accusump for hard braking so i didn't have to pull the parachute. 9.50s and quicker, 140 mph or more.
[Re: rick4106]
#2527881
07/27/18 02:04 PM
07/27/18 02:04 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
What heads and block? Certain heads don't drainback near as well as other and its the same for some blocks. If you run a vacuum pump and see high vacuum levels you may need a bit more oil there too.
[Re: rick4106]
#2529385
07/31/18 02:36 AM
07/31/18 02:36 AM
gregsdart
I usually don't but heads with other sugestions, but now is the time.DO NOT run less than 10 quarts (9 plus one for filter) in that pan! You can watch your oil pressure carefully and cut back a bit at a time if you like, and see what your package will tolerate. But if you do, i suggest a very resposive gauge to show you any momentary starvation, and/or a high pressure idiot light.
[Re: gregsdart]
#2529610
07/31/18 04:52 PM
07/31/18 04:52 PM
Cab_Burge
I have used several different size lines for oil pressure, 1/4 inch line is way more responsive to oil pressure changes than the 1/8 or 1/16 lines are NHRA had a rule at one time that didn't allow any oil pressure line bigger than 1/8 line
[Re: rick4106]
#2529938
08/01/18 12:40 PM
08/01/18 12:40 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Son has a 496 lo deck with milodon dragster pan. Part # 31161 with dual line pump and remote wix spin on filter. Milodon shows 9 quarts plus filter. What oil capacity is everybody using? I cringe at the thought of running anything buy a Jomar No-Bypass oil filter on my RB. The thought of not filtering 100% of the oil 100% of the time scares something in me deep down inside....my motor.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Cab_Burge]
#2530321
08/02/18 02:12 AM
08/02/18 02:12 AM
jbc426
West Coast, USA
All of the Ford and Mopar oil filters I have heard of all where bypass types, the Wix standard filter bypasses 20% and the race filter are suppose to bypass 40% I have used the Oberg screen filters also, they have a built in bypass also but you can set them up so they will make a light come on when they start to bypass As far as metal bypassing the oil filter versus how small the particles the filter will pass through it the filter media determines that , doesn't it All the GM filters are 100% filtered but the motor will loose HP when using them also Good info, Cab. I read that pressure drop at the filters is an indication of not enough filtration capacity, and that must be where the HP loss is. Jomar does a good job of explaining the pressure drop and the no=bypass benefit on their website, and I based my choice of filters on that.
