Hydraulic Roller Cam in 440 #252985
03/13/09 07:22 PM
03/13/09 07:22 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I picked up a set of hyd roller lifters at a good price. They are made by CAT. Anyone have and experience with these?
I'm also kinda rethinking the hyd roller cam idea. There doesn't seem to be many off the shelf cams available for BB Mopar's.
What do you think - roller or flat tappet in a 440? Any advice greatly appreciated.
Thanks,
Steve
Re: Hydraulic Roller Cam in 440 [Re: srunge55] #252986
03/13/09 07:46 PM
03/13/09 07:46 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I can't help with the Cat rollers. Comp lists a few hyd. rollers for BB's. I know they will grind whatever you want for a few bucks more. With all the oil issues I say go roller. I did a street solid roller in my 470" and love it!
Re: Hydraulic Roller Cam in 440 [Re: Dcuda69] #252987
03/13/09 08:18 PM
03/13/09 08:18 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
What is the life span of hydraulic roller lifters in a street driven car?
Re: Hydraulic Roller Cam in 440 [Re: Snoopy] #252988
03/13/09 09:33 PM
03/13/09 09:33 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
ask everyone with new trucks I think they bin hydraulic rollers for years!!!
Re: Hydraulic Roller Cam in 440 [Re: Dodgem] #252989
03/13/09 11:36 PM
03/13/09 11:36 PM
Snoopy Offline
Snoopy  Offline
That's what I though, but I seem to remember a few posts that stated the after market rollers where not very reliable and needed rebuilding or replacement after very few miles. After reading all the horror stories concerning flat tappet cams, I would like to go with a hydraulic roller cam in my Hemi. But was holding off until I could get more information concerning their pros and cons.
Re: Hydraulic Roller Cam in 440 [Re: Snoopy] #252990
03/14/09 09:16 AM
03/14/09 09:16 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i think one of the problems is that people think they can get solid roller performance from a hydraulic roller. a hydraulic tappet, roller or flat, can only be accelerated so fast. the faster the hydraulic tappet is accelerated the quicker it fails. i've looked at advertised profiles from comp cams, engle and crane and have never seen anything that impressive for the extra $1000. i can buy a lot of ZDDP for a $1000. the hydraulic roller retro-fit stuff is just another pit to throw money in. if you want roller performance, then buy a solid roller.
Re: Hydraulic Roller Cam in 440 [Re: lewtot184] #252991
03/14/09 01:18 PM
03/14/09 01:18 PM
Snoopy Offline
Snoopy  Offline
The posts I read mentioned the need to rebuild the roller rather than the hydraulic part of the lifter.
The reason I was considering a hydraulic roller was because of all the problems reported concerning flattened lobes on flat tappet cams. I am not looking forward to a engine full of cam & lifter particles.
Re: Hydraulic Roller Cam in 440 [Re: Snoopy] #252992
03/14/09 01:23 PM
03/14/09 01:23 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Thats certainly an option, but if your not running real high lifts/heavy spring pressures then flat tappets can survive just fine--just pick your oil with a little thought and no problem. Lots of options regarding the oil IF you look.
Re: Hydraulic Roller Cam in 440 [Re: srunge55] #252993
03/14/09 03:25 PM
03/14/09 03:25 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I have a Crane hyd roller in my 440..have about 4000 miles on it..has required no maintenence...several 1/4 mile passes ..Now i think I am going to have Tim at bullit cams regrind it as its kinda mild now..regrind is about 1/2the price of a new one.Or maybe i will try to sell it for 1/2 the price and just buy a new cam..but hyd roller for a driver and sometimes racer is the way to go...
