Duster Tire And Wheel Sizing #252971
03/13/09 07:04 PM
03/13/09 07:04 PM
Anonymous OP
Anonymous OP
I have a 71 Duster mini tubbed using stock wells widened to rails. I want to use a 10x28 Mickey Thomphson slick with a stock width A Body 8 3/4 housing. What wheel offset will I need with a 10 inch wheel?
Re: Duster Tire And Wheel Sizing #252972
03/13/09 08:02 PM
03/13/09 08:02 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
If your leaf springs are mounted in to the frame rails also. 15X10 7.5 BS Is what I used with that combo.
DC
Re: Duster Tire And Wheel Sizing #252973
03/13/09 09:27 PM
03/13/09 09:27 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
We have 15x10 with 5.5 backspacing with 275/15 drag radials on our 71 with stock wheel tubs and offset spring hangers. If your springs are moved in with the tubs 6.5 would work and you would still have some dish left on the outside.We trimmed the outerlip. Below is a pic.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
