5.9 Cummins from a bus..... #2529028
07/30/18 02:14 PM
07/30/18 02:14 PM
Escondido, California
JonGottaDemonDad Offline OP
I picked up a low mileage 5.9 24v cummins to put it into an old jeep. I picked up a dodge transmission to bolt onto it. When I tried to put it together the snout on the crank is like 3 inches long.
When I google photos of the stock 5.9 24v it looks different than my engine.
Any advice on how to correct this?
I was thinking about cutting it off with a bandsaw....
It was bolted to an Allison transmission when I bought it.
Craig
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529137
07/30/18 04:54 PM
07/30/18 04:54 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
Why not use the Allison transmission?
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529156
07/30/18 05:45 PM
07/30/18 05:45 PM
no overdrive and no parking brake. Not a solution for a daily driver.
Craig
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529235
07/30/18 08:29 PM
07/30/18 08:29 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think that you have an adapter on the end of your crank that mates up the allison---dont let it fall off on your toe-----also on the 4bt site there are guys always looking for the high mount AC unit and the air compressor found on those bus motors---good score...
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529351
07/30/18 11:57 PM
07/30/18 11:57 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
hopefully it is a removable adapter as you need to be able to put the converter in the hole in the end of the crank so just cutting it off flush wont work.
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529357
07/31/18 12:08 AM
07/31/18 12:08 AM
you my friend are a legend......
savoy64
Thanks so much!
Craig
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529375
07/31/18 12:48 AM
07/31/18 12:48 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
my toe still hurts.....
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529457
07/31/18 11:50 AM
07/31/18 11:50 AM
i listened to your warning and I was not expecting the entire thing to pop off it hit me in the shin and missed my toes by like a 1ft.
Whew.....
Craig
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529524
07/31/18 02:19 PM
07/31/18 02:19 PM
Guitar Jones Offline
Just as a side note, the converter registers into the flex plate and not the crankshaft.
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529866
08/01/18 09:53 AM
08/01/18 09:53 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If that water valve on the back of the head gets in the way it can be removed. There’s a large core plug in the pickup version.
