Re: 5.9 Cummins from a bus.....
[Re: JonGottaDemonDad]
#2529351
07/30/18 11:57 PM
07/30/18 11:57 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
hopefully it is a removable adapter as you need to be able to put the converter in the hole in the end of the crank so just cutting it off flush wont work.
#2529524
07/31/18 02:19 PM
07/31/18 02:19 PM
Posts: 20,625 in a cattle trailer down by th...
Guitar Jones
Just as a side note, the converter registers into the flex plate and not the crankshaft.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
