Page 1 of 3 1 2 3
another plug read #2528826
07/29/18 11:14 PM
07/29/18 11:14 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
just pulled the ngk7's after running on a mix of race fuel. combination of around town, freeway and some full throttle blasts. Gonna try some champion rc9yc in it. Comparible to a ngk6.
Re: another plug read [Re: mopar dave] #2528834
07/29/18 11:41 PM
07/29/18 11:41 PM
Washington
madscientist Offline
Washington
It's rich.
Re: another plug read [Re: mopar dave] #2528837
07/29/18 11:53 PM
07/29/18 11:53 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
??? WOT run it to the middle of 2nd gear (auto), kill the engine, pull over, and pull a plug. This tells us nothing.
Re: another plug read [Re: mopar dave] #2528840
07/29/18 11:58 PM
07/29/18 11:58 PM
If the bottom pictures is of the NGK6 they are to hot down
If not confused
How much total timing are you running with these pictures?
Re: another plug read [Re: gsmopar] #2528854
07/30/18 12:22 AM
07/30/18 12:22 AM
Mt Morris Michigan
Mt Morris Michigan
well, i can tell ya this. wide open on my wide band reads 12.5-12.6. very safe there. Thats way more accurate than reading the plug. Plugs are just too hard to read.
Re: another plug read [Re: Cab_Burge] #2528856
07/30/18 12:23 AM
07/30/18 12:23 AM
Mt Morris Michigan
Mt Morris Michigan
no, they are all 7's and timing is all in at 36* now with the race gas.
Re: another plug read [Re: mopar dave] #2528857
07/30/18 12:25 AM
07/30/18 12:25 AM
Washington
Washington
It may be fine at WOT but that thing is pig rich at a cruise and I'm not going to say you are correct at WOT until you kill it clean and cut the plug apart.
I don't care what the A/F meter says that thing is pig rich at idle and cruise. Do I need to post a picture of what a decent tune up looks like? I trust my ability to read a plug long before I trust that gauge. That's for damn sure.
It's PIG rich.
Re: another plug read [Re: madscientist] #2528862
07/30/18 12:35 AM
07/30/18 12:35 AM
Mt Morris Michigan
Mt Morris Michigan
ok, than. it may be pig rich, but it sure does run good pig rich. sounds very happy. I might try putting the t slots back to .055 from .059 and see what the results are there. That did richin things up a bit. Thanks guys
Re: another plug read [Re: madscientist] #2528870
07/30/18 01:00 AM
07/30/18 01:00 AM
Mt Morris Michigan
Mt Morris Michigan
Can you post a plug with a proper tune? I really would like to see it. The camera makes them look darker than they really are. They are dark grey in color. What part of the plug are you looking at that says pig rich to you?
Re: another plug read [Re: mopar dave] #2528892
07/30/18 02:19 AM
07/30/18 02:19 AM
Washington
Washington
I will go out in the morning a grab a couple. They should be white.
Hope I can figure out how to post a picture here. I've never done it. I may have to email them to you and let you post them.
Re: another plug read [Re: mopar dave] #2528898
07/30/18 03:05 AM
07/30/18 03:05 AM
FWIW Wallace racing has good plug tuning pics/info.
Re: another plug read [Re: madscientist] #2528926
07/30/18 09:56 AM
07/30/18 09:56 AM
Mt Morris Michigan
Mt Morris Michigan
cool. where ever you get a chance. cudadave@outlook.com
Re: another plug read [Re: mopar dave] #2528950
07/30/18 11:21 AM
07/30/18 11:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think plug reading with street driving and pump gas is going to be a waste of time. If it feels happy and good roll with that. You are going to have poor distribution at low load and overlap and reversion further messes things up. Your intake isn't designed for putzing around town, it is designed with a RPM range in mind, when it is running in that range distribution will be way better.
68 Barracuda Formula S 340
Re: another plug read [Re: Bad340fish] #2528990
07/30/18 12:50 PM
07/30/18 12:50 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Yup.
Re: another plug read [Re: mopar dave] #2529052
07/30/18 02:43 PM
07/30/18 02:43 PM
I get the best plug colors with 14.5 AFR or leaner(up to 15.5 AFR cruise or idle) at idle and light part throttle cruise RPM below 2500 RPM up scope
I agree with the mad scientest on plug colors, white to very light tan is perfect up
Dominic and I have seen the same thing your seeing and feeling with the AFR rich, richer feels good but leaner is meaner except at WOT up
Re: another plug read [Re: mopar dave] #2529057
07/30/18 02:49 PM
07/30/18 02:49 PM
Washington
Washington
I just sent Dave three pictures of plugs that came out of my car to post. As soon as Dave gets to it, I'll post some comments.
Thanks Dave
Re: another plug read [Re: Bad340fish] #2529085
07/30/18 03:28 PM
07/30/18 03:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Kinda how I approach it these days with the WB being a directional tool more than locked in stone........ thumbs
Re: another plug read [Re: madscientist] #2529092
07/30/18 03:39 PM
07/30/18 03:39 PM
Mt Morris Michigan
Mt Morris Michigan
Pics sent to me.
Re: another plug read [Re: mopar dave] #2529100
07/30/18 03:47 PM
07/30/18 03:47 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’d be very surprised if a combo like Dave’s actually drove well with the a/f meter reading hi-14’s to lo-15’s.
For part throttle operation I get them to drive to my satisfaction, and whatever the a/f ratio is..... so be it.
Re: another plug read [Re: fast68plymouth] #2529105
07/30/18 03:53 PM
07/30/18 03:53 PM
Mt Morris Michigan
Mt Morris Michigan
Yep. Runs like crap cruising at 2500 and below rpm. Sounds like misfires. Lean misfires? Cruises best in the 13.0 to 13.8 range.
Page 1 of 3 1 2 3
