Re: Mod Sequence
[Re: broncobra]
#252884
03/14/09 04:56 AM
03/14/09 04:56 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I'm no chassis expert, but I believe you want to do spring relocation before minitub, as the first helps dictate the position of the second, and then do your subframe connectors and then your torque boxes last.
I have installed subframe connectors on two cars, both times on cars with exisisting torque boxes. One car by slotting the torque boxes installing the connectors and then welding up the slots, and the other car by peeling back part of the boxes installing the connectors and rewelding the boxes back in place.
In other words, Move your springs, install your minitubs, install your connectors and then put the torque boxes on last. I have never altered the spring location or installed minitubs though. I'm sure many guys have here though.
Pic of the peeled back and re-welded ones, after spraying with black semi-gloss paint...
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Mod Sequence
[Re: jbc426]
#252885
03/14/09 05:49 AM
03/14/09 05:49 AM
jbc426
West Coast, USA
The slotted ones before final grinding, sealing with high-quality, paintable, black 50 year roof and gutter caulking and finish coating with Resto-Ricks undercoating...Notice how close the front spring mount and wheel house are to the parts. It's something to consider when determining your project sequence.
Re: Mod Sequence
[Re: jbc426]
#252886
03/14/09 03:36 PM
03/14/09 03:36 PM
Posts: 550 ne
broncobra
ne
