leaking oil pump gasket - reassembly question #2527815
07/27/18 11:58 AM
07/27/18 11:58 AM
Greenwood Lake, NY
fuelishnsilly Offline OP
Greenwood Lake, NY
So I picked up an oil pump rebuild kit as my oil pump is leaking badly where the pressure spring retaining bolt goes in. The kit includes the new clover leaf drive shaft and companion circular part of the pump that goes into the housing. Do I need to pack the vanes of it with grease to create a prime or would simply putting a film of oil on everything be ok? Also, do I need to drain the oil pan or can I leave the oil in there and just replace the pump and filter?
First time I'm ever doing this and I'm pretty sure this is the first time the oil pump has been off this car.
inherited a 69 roadrunner from my grand pop.
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2527842
07/27/18 12:46 PM
07/27/18 12:46 PM
Kirkland, Washington
Pacnorthcuda Offline
Most likely oil will work just fine....BUT...the more cautious method is to assemble the pump with a film of Vaseline on the rotor and hub, you don't have to fill the cavities.
Once engine is fired The Vaseline will quickly dissolve into the oil and not cause any issue.
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2527851
07/27/18 01:02 PM
07/27/18 01:02 PM
Greenwood Lake, NY
Greenwood Lake, NY
Ok. Thanks. Do I need to drain the oil from the pan or is that not needed?
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2527854
07/27/18 01:04 PM
07/27/18 01:04 PM
No need to drain the oil pan. We ARE talking a big block motor right?
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2528184
07/28/18 04:43 AM
07/28/18 04:43 AM
I clean them thoroughly and then coat all parts in thin engine oil thoroughly before assembly, the scroll, the rotor and stem as well as coat the pump inside where the scroll rides and the cover where it rides also.
Skip the vasoline or any grease in the pump tsk
As far as the pump leaking by the bypass valve replace that gasket and retighten it again after getting the motor up to normal operating temps, do NOT over tighten it tsk
Good luck up
Let us know how it goes thumbs
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2528366
07/28/18 06:52 PM
07/28/18 06:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Rebuilding a whole pump because of a leaking spring cap gasket?
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2528405
07/28/18 08:47 PM
07/28/18 08:47 PM
Greenwood Lake, NY
Greenwood Lake, NY
It’s not a cap gasket. Seems to be leaking pretty good from the gasket at the pressure spring bolt. Losing about a quart an hour driving it.
Any tricks on how to get just that bolt out? Steering box is blocking it or the bracket for the motor mount is. I can’t remember which but I know it couldn’t get a wrench or socket on it from under the car.
Yes it t is a big block engine.
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2528444
07/28/18 10:37 PM
07/28/18 10:37 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Pull the pump off if it's that tight, by the time you get it back together you'll have the thing full of grime and not holding pressure. I have seen the boss that holds the pressure spring crack.
I'd put a new pump on it at this point, there not expensive.
Have a great day
Iowan
"obsolete is neat"
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2528501
07/29/18 02:10 AM
07/29/18 02:10 AM
Greenwood Lake, NY
Greenwood Lake, NY
Hmm. What would cause that boss to crack out of the blue?
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2528660
07/29/18 04:25 PM
07/29/18 04:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Once again the English language causes confusion, what you're calling a "bolt" is a "cap" in factory lingo.
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2528665
07/29/18 04:38 PM
07/29/18 04:38 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
It's been on motors I've gotten from yards or picked up used, at one time I had close to 20 rb blocks. Now I have 4.
Have a great day
Iowan
"obsolete is neat"
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2528801
07/29/18 10:20 PM
07/29/18 10:20 PM
Greenwood Lake, NY
Greenwood Lake, NY
ok, thank you for the correction John. I thought it was more of a bolt than something that short like a pipe plug.
Iowan,
I'm still confused as to what would cause the oil pump housing to crack? Its not like it is under that much torque or subject to abuse like the rest of the block.
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2528823
07/29/18 11:03 PM
07/29/18 11:03 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I have no idea other than flaw in casting, abuse or over tightning of the cap.
Have a great day
Iowan
"obsolete is neat"
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2529461
07/31/18 12:01 PM
07/31/18 12:01 PM
Greenwood Lake, NY
Greenwood Lake, NY
Ok, so I finally got a chance to work on it last night. I pulled the oil pump off and when I got it out, I put the case in a vice and went to remove the pressure relief cap. The cap was a little less than snug which I'm guessing is why it was leaking. I pulled it all apart and checked everything out while I had it off, everything looked in great shape so I put it back together after cleaning it all up and oiling the internal parts with a thin film of 5w-20 that I had laying around. Didn't get a chance to fire it up last night but I'll take care of that when I get home from work today.
Thanks for all the help.
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2529658
07/31/18 06:31 PM
07/31/18 06:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Gaskets shrink with age.
Re: leaking oil pump gasket - reassembly question [Re: fuelishnsilly] #2530262
08/01/18 11:22 PM
08/01/18 11:22 PM
Greenwood Lake, NY
Greenwood Lake, NY
Understandable but I would have imagined something that was exposed to oil like that wouldn't shrink. I could see if the car hasn't been run in 20 something years which this has had starts almost every month to keep stuff lubricated.
