Page 5 of 5 1 2 3 4 5
Re: How much does rear gear ratio effect HWY gas mileage? [Re: 360view] #2510904
06/20/18 04:52 PM
06/20/18 04:52 PM
Des Moines IA
Soopernaut Online content
Soopernaut  Online Content
Des Moines IA
Originally Posted By 360view
Anyone here on Moparts presently driving a Ford F150 with the 2.7 L twin turbo V6 ?
Does the Ford trip computer allow you to view the MPG at a steady level highway speed?
How many psi of boost is needed to drive in the 60 to 75 mph range on a level highway?
http://www.wardsauto.com/engines/2018-winner-ford-f-150-27l-ecoboost-twin-turbo-v-6
Yes
Yes. There are so many variables but throttle input seems to have the biggest effect on the gauge reading. I can have a wide difference in MPGs at the same speed on a relatively flat highway. I do most of my driving in the city and can get better mileage than I get at times on the highway, if it is not stop and go. If I drive 40-60 MPH on a flat road with no stops I can get MPG readings of near 30 MPG. At 70-75 MPH I generally get low 20s, but at those speeds the road can have more changes which affect the readings. Overall city MPGs average in the upper teens. Cold weather and stop and go traffic can have a large effect on the city readings. I do have 3.73 gears which could affect the highway mileage some and perhaps benefit city driving. Some others have mentioned sustained MPGs in the mid 20s with the 2.7L.
I have an XLT which does not have a boost gauge standard. Higher trim levels have the boost gauge and I'm sure some have added it to their XL/XLT trucks.
Many of the F150 forum members claim lower MPGs with the 5.0, which seems to be the consensus. The 3.5 Ecoboost is between the 5.0 and 2.7 in terms of mileage. The 5.0 with the 10 speed seems to be a better match than it is with the 6 speed.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: How much does rear gear ratio effect HWY gas mileage? [Re: ragtop] #2511282
06/21/18 12:40 PM
06/21/18 12:40 PM
Frederick , MD
GibW340 Offline
GibW340  Offline
Frederick , MD
Originally Posted By ragtop
Anyone measured there highway gas mileage before and after a gear swap?
If so, can you post some numbers. Even if it was somewhat steady state rural road driving. I know that city or around town driving won't be hardly effected by gear ratio.
Thank you.
A factor to consider is where and how you are driving- Long distances at higher speed would be better with lower ratioo
More stop and go low speed- somewhere the higher # ration would be more effiective it would seem
Re: How much does rear gear ratio effect HWY gas mileage? [Re: ragtop] #2512071
06/23/18 10:06 AM
06/23/18 10:06 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
http://www.hotrod.com/articles/1010sr-quick-change-rear-end/
Being able to quickly change diff ratios could answer a lot of questions similar to those in these posts.
In these days of CNC
it would also seems that making
custom planetary gear sets
to go inside Chrysler 46/47/48 OD units
would not be that hard or expensive.
Swapping OD units would just slightly more work than changing
straight cut gears in a Quick Change,
and those extra gears in a Quick change add friction drag, perhaps 2 to 4%.
Re: How much does rear gear ratio effect HWY gas mileage? [Re: HotRodDave] #2515310
06/30/18 03:17 PM
06/30/18 03:17 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By HotRodDave
my 2000 dodge van with a 5.9 and 3.92s is close to that fluctuation and it definately locks solid in lock up. It will not hold the speed as precise as my 2011 1500 ram did on the data stream on my scanner or in real life on the freeway running side by side.
I have a set of 3.21s to install, I am positive they will give me better highway MPG.
Interesting, my scanner would stay at 60 then going down a hill would creep to 61 but rpm would go down to 1888. All over the place. I'm thinking the converter is not locking up to well (all new parts, electrical and trans). Will the lockup fluctuate 100 rpm?
I have a set of 3.54 for the Dana that I would like to try. Talked to the Dodge service man, he said no problem reflashing pcm for the ratio change.
Dont waste money taking it to the dodge dealer for a "flash" after a ratio change, the vehicle speed is measured after the gears and will not affect anything computer related changing gears.
Thanks, just removed the speed sensor connector on trans checking what you said, speedo still works! It does work off the rearend. 3.54s are going in today!
Re: How much does rear gear ratio effect HWY gas mileage? [Re: ragtop] #2516056
07/01/18 09:14 PM
07/01/18 09:14 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Update, 3.54 gears are doing fine. Just floats along with very little pedal effort at 50-60 and mph is dead on. Used the state police mile lay off signs on the highway, cruise set at 60, I went 59.96 seconds so that's real close. Filled up today so in about 100 miles I'll check millage, feels like it will be better than 13.5 mpg, hope, hope. Van just feels all around much better, didn't lose any power that I could tell.
Re: How much does rear gear ratio effect HWY gas mileage? [Re: GoodysGotaCuda] #2524878
07/21/18 07:03 AM
07/21/18 07:03 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Originally Posted By GoodysGotaCuda
Axle efficiencies come into play. The internals of the transmission [working through a fluid] driveshaft and axle gears [working through a fluid] have to spin at higher rates, consuming more energy.
Last week I did some very unscientific testing in my '73 Dart (360ci A518, 3.55:1 in a 8-3/4 rear axle).
Tried to measure drivetrain losses with the help of the MegaSquirt ECU and TunerStudio.
Proceded by raising the rear tires just of the ground, put transmission into Drive, throttle it a bit and let it upshift to 3rd and into OD.
Then I let the engine 'idle' with the wheels spinning, making sure the trans stayed in 3rd+OD by looking at the speedometer.
Then I checked the engine-load kPa with TunerStudio.
Did the same with trans in neutral.
Difference in load with transmission in Neutral and in OD was just 5 kPa (30kPa in N, 35kPA in OD).
About 5 kPa drivetrain (transmission & rear axle) loss, at low rpms.
Now I didn't test at higher speeds to see if the difference would be greater.
Re: How much does rear gear ratio effect HWY gas mileage? [Re: ragtop] #2524902
07/21/18 10:38 AM
07/21/18 10:38 AM
USA
3
360view Offline
360view  Offline
3
USA
Interesting test.
Is the kPa that TunerStudio calculates something similar to
“Brake Mean Effective Pressure” BMEP?
With the Oztrip meter one readout is gallons per hour consumption.
When my Magnum 5.9V8 is in warmed-up idle using gasoline without ethanol the Oztrip displays 0.65 GPH.
If I turn the high beam headlights on at idle this will rise to 0.66 or 0.67
If I turn the air conditioning on at idle this rises to 0.71
Re: How much does rear gear ratio effect HWY gas mileage? [Re: ragtop] #2524914
07/21/18 11:27 AM
07/21/18 11:27 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
with such a small change in the numbers one wonders if any of that is voltage drop due to more load?
Don't be the exception.
Re: How much does rear gear ratio effect HWY gas mileage? [Re: ragtop] #2525069
07/21/18 07:05 PM
07/21/18 07:05 PM
The Netherlands
The Netherlands
'kPa' can be seen as an inversed vacuum number.
I could have done the test with a vacuumgauge as well, but the kPa-reading in TunerStudio was more detailed.
100-101 kPa is about barometric pressure = 0 in/hg vacuum = Sealevel airpressure.
50 kPa is about 15 in/hg vacuum
0 kPA is about 29.5 in/hg vacuum
30 kPa = 20.7" vacuum
35 kPa = 19.2" vacuum
So in short, engine vacuum went from 20.7" at idle, to 19.2" with trans in OD.
My MegaSquirt-setup doesn't control fuel yet so I couldn't read any calculated fuel consumption numbers.
Re: How much does rear gear ratio effect HWY gas mileage? [Re: cudaman1969] #2525081
07/21/18 07:34 PM
07/21/18 07:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Update again, first millage check going from 4.10 to 3.54.
13.1 to 14.6 mpg all around, almost ready for another fill up. I'll average the two this time.
Re: How much does rear gear ratio effect HWY gas mileage? [Re: ragtop] #2528536
07/29/18 08:45 AM
07/29/18 08:45 AM
The Netherlands
The Netherlands
I did 2-hour roundtrip yesterday with my setup (360/A518/3.55); 13.3mpg.
Average engine rpm was 2200-2300rpm between 65-70mph.
Will probably be changing to 3.23 gears soon and try to do a similar test.
I think the small gearchange will be less effective and probably not even "worth it" for mileage.
Re: How much does rear gear ratio effect HWY gas mileage? [Re: ragtop] #2528587
07/29/18 12:33 PM
07/29/18 12:33 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Last nite fill up, third since change, 14.91. A lot from the 13.1 with 4.10s. 100 miles on interstate at 70-75, rest around town from 25-60. Rpm is about 1700 at 60 iirc (have to use the hand held unit, no stock tack)
Re: How much does rear gear ratio effect HWY gas mileage? [Re: ragtop] #2529150
07/30/18 05:28 PM
07/30/18 05:28 PM
USA
3
360view Offline
360view  Offline
3
USA
Along with the MPG
test how steep a hill you can climb in top gear without a downshift.
Many customers will complain that their vehicle is “gutless” if it will not climb a 4% grade interstate highway hill at 75 mph without downshifting.
Re: How much does rear gear ratio effect HWY gas mileage? [Re: ragtop] #2529397
07/31/18 07:50 AM
07/31/18 07:50 AM
The Netherlands
The Netherlands
Eventhough I live in a super flat country, the previously installed low CR 318 in my daily would have trouble maintaining speed with some gradients in OD with a 3.23 gearing in the axle.
After a swap to a digital ignition with a better curve and 3.55 gears the problem was gone.
Now with the 11.3:1cr 360ci there are no issues at all with changes in road altitude.
